This is the official thread for the Topping A50
- 2.5mm balanced out and 1/4 inch and 3.5mm unbal out, RCA in and out
- 2200mW @ 64ohms bal and 1110mW @ 32ohms unbal
- Higher output impedance (something to note)
what is the note about Higher output impedance (potential warning) for? like what bad things can it cause?
Typically with lower impedance headphones it can end up modifying the frequency response of the headphone (basically, simplifying here). Itâs like around 10 ohms output impedance unbal and like 5 ohms bal so you want to use higher impedance headphones to avoid extra coloration anything over 100 ohms would be fine but if you use something like 30 ohm headphones it might be pretty noticeable
oh ok, I kinda got the impression from the posting that you could blow the drivers out os some shit.
Ok, made it less ominous lol, itâs just something to note with it
while Iâm not in the market for one of these. I do have to ask. Does it come in black?
kinda related, before I settled on my new dac I had thought about getting a D30, but in topping website they did not show having a black one. While on amazon you could find one in black. I did not buy it as I assumed it was a fake. But is there any way to know for sure? buying anything from china is super shady as is.
Well I mean the d30 is an older dac and imo the d10 is better sounding
Still no reviews about it, and ASR still not âmeasuringâ it.
Itâs weird.
IMO they just canât compete with the cheap SP200, Atom (etc.) right now.
Oh well, do like everyone else and get an Atom + D50/D50S stack. ![]()
Just found this on YouTube. https://youtu.be/sw_ZnYs6GtE Only review I can find online.
Finally ![]()
In what way does it sound better? I skipped it because I thought it was too cheap, I wanted a real power cable and I like the extra input options.
Is it just a better chip? On ASR they said you could not tell any difference, sound wise.
Itâs so minute it doesnât matter too much. I personally think itâs slightly cleaner sounding but it really doesnât matter that much, I just think if you donât have a dac I would just go for the d10 because itâs newer and also a slightly better USB implementation. But realistically they sound super close, I really only noticed on higher end gear
Anybody get the A50s yet?
ASR has the A50s maxing out its measurables.
I have the D50s running with a Chromecast Audio Puck and love it. Thinking of grabbing this to just pair it with the D50s for posterity.
Any difference between the A50 and the A50s except that the A50s wasnât measured by Amir? Lol.
More power.
Pre-Amp.
I just ordered the A50s from Apos and I should have it sometime next week.
I was going to get the A90 but after seeing the review and measurements on ASR I figured why not save $300 and get the A50s since it uses much of the same architecture as the A90 just with less power and a smaller form factor, plus, I already use the D50s as my main Dac. I mean 3.5 watts at 32ohms in the balanced output is plenty of power for all my headphones and really most headphones for that matter. The A50s measures better than my THX SP200 and from what Iâve read I think it will sound better as well with an even more transparent sound. It looks like itâs almost a mini A90 and while I donât expect it to be quite as good as the A90 I do think it will be close and saving $300 makes it worth it to me.
Yeah, if you donât need balanced, A90 is a waste of money.
Same for the Topping DX7 all-in-ones vs the D50S, probably. (If itâs not the same chip, itâs the same implementation, the same âToppingâ sound â but you choose the amp).
Has the A50s âresolved the higher output impedanceâ adequately that it is not a going to be a âissueâ?
Edit: appears it hasâŚsweet!
