đź”· Topping D10s
This is the official thread for the Topping D10s
  • USB in, coax and toslink out, rca line out
  • ES9038Q2M, 32/384:
  • Refresh for D10
:red_circle: Hifiguides Amazon Link
[Reviews]
Z Reviews
Features:
ES9038Q2M DAC
XMOS XU208
PCM 384kHz
DSD256
THDD+N 0.0002%
Analog + Digital output
More: TOPPING D10s Hi-Res USB DAC ES9038Q2M 32Bit/384kHz DSD256 XMOS XU208 HiFi Decoder — HiFiGo
Wonder when zeos will get one.
Measures better than the D10, as good as the E30 for 30$ less, even.
It’s ess vs akm, so it comes down to preference and pairing I would say
Definitely.
Please don’t choose one over the other because there’s a 10dB difference of distortion when your ears were bleeding “30dB ago”. :stuck_out_tongue:
I’m thinking of replacing my E10K with a DAC that will nicely stack with the Liquid Spark, both in terms of sound and physically since I plan to get one of those acrylic tower thingies and put them on my desk.
I’m thinking the D10s would be my best bet since the E30 is a warmer DAC and the Liquid Spark is also a warm Amp and I’m not necessarily looking for a very warm sound (choose the LS to pair with my now deceased DT880). The headphone I will mainly use are the HE400i (2020).
The D10s costs €100, the E30 costs €139, so the D10s is also significantly cheaper. Should I still choose the E30 over the D10s or are there other DACs I should take into consideration?
(No Drop, because Europe and customs and delivery and all that)
EDIT:
Another option would be the FX-audio DAC-X6 MK II which has Bluetooth which would be really nice to have. However if the sound is significantly worse than the D10s I prefer to lose Bluetooth over sound quality.
I’m getting some noise from my PC USB port, if I go USB from PC to D10s to optical out to my main DAC, would it degrade sound quality?
I have been using the D10s as a USB bridge to my D90. Yesterday Z was quite positive reviewing a new piece from Topping (M50) that is essentially a Streamer and a bridge (as well as quite a bit more) So I ask you fine people…If I buy the M50, does it replace what the D10 does (essentially cleans up the USB feed from my desktop)? Would it hurt to use em both? I would appreciate any guidance here.
I’d try them both. They are cheap enough as a stack and damn that M50 has a ton of features so I really don’t think you’ll lose our if it doesn’t accomplish exactly what you want.
That’s exactly what I was thinking!!! Topping seems to make sure their stuff plays well with each other. Thanks for your reply!!!
