did you use the smallest nozzle?
Problem with the Starlight is that while it’s solid for most of its tuning, the treble is truly insane:
For anyone wondering, that target is loosely based on the Clairvoyance (a bit bassier than ‘neutral’, but I like it), so that should give somewhat of a reference point.
It’s the nozzle with 4 drivers connected - the EST drivers.
Use really tiny bit of sponge, it has to be a bit loose in the tube. See how much I used, you don’t need much otherwise you are going to kill treble altogether.
I heard the NANA was better than these at 900$
and then Mest is better at 1100$
Starlight can be bought on sales for 500-600$
