Only the 5K has PEQ from what I know.
(of course, you can still use PEQ if you are using local files, like with poweramp, Neutron and UAPP.)
Like fiio uwts 3?
I will also add the Shanling UP4⦠I love the value wheel over Btr5, qudelix
yes exactly !
Yeah, but Q5k saves the preset I think. Like you unplug from phone and plug it into pc, will keep the eq.
I dont eq, but some people might find it atractive.
@SpiderTool better check out this thread:
I think theres some bad QC reports on those
Shanling UP4⦠when it comes to battery << owned it
Also cheap, cool!
Oh u want it to be TWS
Yup! Although Iāve seen a LOT of chatter about EQing in some other forums here
Lol, yeah be careful⦠Lol
Hmmmā¦.
I thought it was similar to what HHB uses with the mele when exercisingā¦.
I have no clue about that and I dont own it. Iāve thought about it but eventually dropped it. Its very pratical tho
The only reason I went with the BTR5 was the ability to have both my PC and Phone connected at the same time. Not having to remove my headphones to take a call during the work day was a nice feature. There is a passable microphone on it too.
I donāt know if any of the others have the feature, but if they do they need to advertise it more clearly.
Qudelix supports this, but you lose LDAC support. I think this applies to BTR5 too.
Qudelix also has a built in mic, which I find to be rather handy
oh, didnt know about that beforeā¦
Guessing you have your library on the PC and just have it connected to the phone as well to be able to answer calls directly?
Haha Iāve been stalking the Timeless forum. Mate things got interestingā¦lol
Ahhahahahahahahahahah
I love a good trolling activity to shake things up.
Keep Mele, you fine.
