LOL
Daddy will bend not break
She wil love the blue
You will never see them again.
If she comes back asking if she can use one of each color at the same timeā¦
Enroll her it marketing classes right away.
Thanks BTW!!
LOL
Thanks BTW!!
anyone know offhand what bluetooth adapters fit (angle iām guessing is all that matters) best on the mele? obviously sound is important but if the fit is janky iād rather not waste time with it.
the KZ one fits my MELEās(and feels good on the ears) but if its not as secure as i would like it, i have to check that the pins are fully inserted every time iām going to use them
Hi, have the manufacturer solved the Meleās condensation problem yet ?
My mele has some background noise like electric leaks when plugged in my computer. When I touch my computer it gone and appears again if I donāt touch it anymore. Would changing the cable help or any other solution?
That sounds like a ground issue. Try changing the cable to confirm or plug into any other music player if you have one
It only appear on my computer, no problem with my phone but my friend have the same problem on computer too
Iāve always found computer motherboard sound to be too noisy for sensitive IEMās, youāll have to use an external dac/amp to get rid of the electrical noise imo.
Use a usb dac. If you have any dongle you should be fine. Apple dongle is amazing and costs 8 bucks. Same goes for the Phone, unless you have an amazing phone like lg V series.
I bought Hiby FC3 for this reason already, doesnāt fix, still some background noise, just a little smaller.
I have background hiss on my ifi zen DAC but none through my Qudelix. Using upgraded SPC cable, SE. I also get weird static noises on 2 of my 3 USB C dongles. Havenāt figured out the cause of these issuesā¦
Ground loop, you need to buy usb isolator
11:48
āBut, if you want a bassy IEM at $50, this, the MELE, is the best tuned of the bunch. Itās the ONLY choice Iāll recommend at $50.ā
I really hate these. Iād like to protect my hearing and the Mele make me turn the volume up far too high with the right music (e.g. Amyl and the Sniffers āComfort To Meā). So much bassy funā¦
I wasnāt shocked by that at all. I canāt count the number of times I have recommended them to people.
I am still waiting on my blue pair, but when it arrives ( I think tomorrow ), it will be the only IEM I have purchased two pairs of. Also I have this totally dope looking cable for it.
My blue Mele arrived and I am pairing it with a XINHS 8 Core 6N OCC Rainbow Blue Cable ( I got it on the 11.11 sale, in 2.5mm balanced ). The cable is a bit stiffer than I expected, but the rainbow works great, and the case that came with it was a nice match too.
Those blue Mele are some of the best looking IEMs out there.
Ohā¦that looks dope
Anyone tried those filters Linsoul are selling? How do they compare to stock ones?
