Mine sounded great out of the box and better as my brain has burned in. As people above mentioned these phones are very tip dependent so it will require some experimenting
yep with diferent tips and or cables for sure.
Same timestamp too, so they are likely on the same on the same plane.
I mentioned above, my Shuoer S12 just off the coast waiting for the port of LA to have staff to unload for 5 days, then a day in customs, and then 5 days in a USPS warehouse in Compton.
Fortunately I was still playing catchup on listening time with my Christmas haul.
Hifigo salesman.
@PopinTeddy hmm somethingâs off about his impressions I feel ![]()
All you have to check is go to the vid description and see if he links Olina ![]()
Heâs never gonna hype a product that he doesnât profit from.
I was really looking forward to the Olinas given the DDâs provenance but Iâll be honest I wasnât sure exactly what to be expect. (Disclaimer: Iâm shite at describing how audio gear sounds, so Iâll keep it short. Please do check out proper reviews from nymz etc
.) I can at least tell you Iâm using SF CP100 L plus balanced Xinhs 4-core graphene cable on M3X with local flacs
Fucking hell these are good - ok let me caveat that - fucking hell these are good with metal. Havenât run through other stuff in my library yet 'cos I got lost after starting with Megadethâs Rust in Peace and went on a Megadeth > Machine Head > Opeth trip. I might try the mesh filter on the nozzle vent for some other genres but honestly havenât felt the need to in current listening session.
Olinas are NSFW - listening with them makes trying to work impossible.
Build is fantastic
like a tank, love the finish, fit and comfort excellent and no issues with any scratches on the face plates. For $99 if itâs in your budget imho they are a no brainer.
And yep, Iâve just ordered another set to have as spares just in case I wear these ones out
@PopinTeddy Just saw your exchange with him in another forum ⊠oh man.
where where i wanna see
Somewhere towards the bottom
How does the lyric hunt work? My Olina arrived today and I got a Post Card and lyrics, but didnât know if I should do something with it? Thanks!
Just take a picture of both sides of this postcard and post it here. Chris then will put your card number to the lyrics list.
Ok. Thanks!
Lyrics are from âSympathy for the Devilâ
Edit: Kinda creepy that this Post is #666! Weird AFâŠ
Theres an Olina for Sale on AVexhanged in case anyone from the US wants one and doesnât want to wait.
