That is not a Gold card.
Everything updated from this thread and discords. If your name isn’t there, please give a ping.
Rock on
The Olina rocks but should you get the urge for more detail but with a similar tuning, try the LetShuoer S12. and wont break the bank either.
Current favorite setup amazon music - mojo - Olina (AZLA Crystal tips) , this is an amazing way to enjoy my music. A Great Big Mahalo to @hawaiibadboy
Someone f*d up my order, I do not have my gold card…
#367 “Now they see what will be, blinded eyes to see” from Metallica - For whom the bells toll
PRO-TIP:
I managed not to destroy the sleeve - the case is to push the box out of it rather than pull the sleeve.
Regarding the build of the shell - you all already know - it is amazing. Cable is also really fine.
Regarding the sound I don’t know, I am on a call for 4th hour straight, but in the meantime I try to tip roll and check the seal and unfortunately I have the same problem as with Mele that up until this point nothing fits to my bad ear canal properly. But I won’t give up
Edit: some quality defects in the faceplates are present though - I would get rid of them by polishing, but still something to notice
Edit2: Moondrop Springs seem like best tips out of what I have at hand at my quarantine as CP100 I left at work. Even though I dont normally like those tips - as they kill bass - with Olina album Radiohead - Kid A sounds STUNNING, crazy good timbre and imaging!!
Hey, I’m number 250. We just need a few more to complete our lyrics!
Amazing - thanks so much for all your work!
2 down, 5 to go!
lets go jimmy fans!!
Goldeeeeenn
Edit: updated
Done Congratz
Done. There’s a lot of blank cards together. Guess we gotta see what @hawaiibadboy wants to do about it, you guys might be close!
It was a close choice between the 2, but decided to support HBB. Need to sell some underused iem before picking up s12 or maybe wait for collab version? How would you describe the difference s12 vs olina?
