šŸ”¶ Tripowin X HBB Olina
May I lay here a quick thinking? I personally don’t really mind it, but this while card game isn’t really fair: some people get a card with part of a 4 lines verse while others get a part of a much bigger verse (more than 15 lines sometimes).
The effect of ā€œone line missingā€ is the same whatever the number of lines is in the verse
So the owners of 15+ verse cards have way less chances of winning than the 4 verse ones.
As stated above, I don’t really mind: I bought the olina because I was curious about it, and I already bought a cable with it. I take all this as ā€œsomething that might be a bonusā€. I consider the number of lines to be a ā€œluck variableā€, as having a golden or silver card is.
But the way. As I said, I bought the Noire cable that was in bundle with olina.
The modular system is not bad: it seems pretty solid. It looks like a ps/2 port, but the thing is you don’t have any exterior indicator to match the orientation of the 2 parts, making the change of Jack less obvious and quick.
The cable itself is 4 core braided. I find that:
  • the cores are too thick, making the cable to thick
  • the cable is a little too stiff for my taste
  • the cable is a little too heavy for my taste
  • the exterior material is a little tacky for my taste
All in all, the cable is not that bad, but it would be better suited for a headphone than an earphone.
Mr #1 :musical_note: :notes:
Check your Paypal :notes: :beers:
I think the Tripowin Jelly Cable much better than the Noire Cable, (16 core vs 4 core). The sound quality of my mele is improved by 1-2 levels than the stock cable. The black background is cleaner and more lively and engaging to my ears.
main difference is the resolution. Details and instrument separation is significantly better which is a planar driver trait.
They pair quite nicely…im loving the Olina and i think it has the potential to shake the market at that price point (and above even)…but i’m a detail whore so my requirements may be different to most.
Warning - hype post :fire:
I wanted to make a list of proven songs that sounds particularly good on Olina (as I read in some reviews it does not fit all genres). The problem is that any song I throw at them at the moment sounds amazing:
  • Fiona Apple - Periphery (beautiful representation of her vocals and layering in the background) Spotify
  • Portishead - Roads (her vocal crushing soul!, drums, beat representation, tonality, little sibiliance (it is in the recording itself and in some sets it is very emphasised)) Spotify
  • Lena Hall - Linger (cover) (her vocal crushing soul on top of piano layer) Spotify
  • Joy Division - Atmosphere (drums, atmosphere as name suggest) Spotify
  • Balthazar - I’m never gonna let you down (sub-bass, mid-bass, male vocals)
  • Carter Burwell - The Last Judgement (In bruges OST) (great piano and double bass kick in) Spotify
  • Four Tet - Unspoken (general timbre, piano, layers) Cymbals are a bit off though Spotify
  • Darkside - Paper Trails (tonality, layers separation) Spotify
  • Nicolaas Jaar - Too many kids finding rain in the dust (sub-bass, layers/instrument separation, nice distorted male vocal) Spotify
  • DJ Shadow ft. Little Dragon - Scale it Back (beat, full-bodied piano, good female vocals, no sibilance, great soundstage) Spotify
This could be END GAME for most of the people looking for great tonality non fatiguing sound with amazing technicalities. This is first 1DD that I truly enjoy (sorry Mele, it never sounded that good so I would look a lot for a best possible fit out there, while in Olina it was worth the trouble (I am not tip roller at all). It and S12 and you have all you need potentally in my mind for both easy and critical listening. I mean you could throw in some Tea in the mix for sure and also be happy for less than 500$. But honestly I would say (after couple of hours not looking at the specific genres like classical and jazz as those are not heavy in my library) that having this and Tea is more of a convenience than really a must and that means something for a member of Tea gang:
TL:DR
Your budget is 50$ - you need to save more money :slight_smile:
Your budget is 100$ - buy Olina
Your budget is 200$ - buy Olina
Your budget is 300$ - buy Olina and S12
Your budget is 500$ - buy Olina and S12 and take someone for a fancy dinner
Your budget is 1000$ - damn, I don’t know what to do with that amount of money.
S12 & Olina, the marriage of sound.
I’ll tell you - buy UM MEXT or Mon mk2 and don’t go out to dinner with your girlfriend for at least a month :relieved:
This is exactly my trio…Olina, S12/Timeless and Mon Mkii.
I prefer the Timeless over the S12 but build Quality is a bit suspect which is why I got the S12.
Oh boy, getting box out of that sleeve is…
Rocking the filter on nozzle vent mod, adds a touch more sub-bass rumble for stuff like PE without sounding like anything has been taken away from the mids or treble. Bonus - Xinhs 4-core graphene I ordered with custom dark grey hardware arrived is a great colour match :ok_hand:
In other news, what will be spare set has also been shipped.
Liking much these new iems!
Let’s see if there’s also luck with cards (don’t know if posted in correct section)
All good Chris will see it :+1:…welcome to HFGF and good luck :four_leaf_clover:
Thank you! Really liked the Mele at that price point but my girlfriend is keeping them so i hope these will be a good substitute :joy:
I got the S12 today as well, is there any bass mods for this as well? Shortbus has mentioned eq settings?
you can try adding a filter (cheap ones from AliX) to the front vent
Is there some advantage to doing a physical mod as opposed to just EQ? I would think EQ is easier to implement, as well as being easier to reverse. Is there a suggestion of a qualitative difference between the 2 approaches?
No, just convinience between sources. EQ is the most precise.
The amount of additional bass proposed by Michael Bruce cannot be achieved with just the filter mod. And also, convenience
S12 respond nice to eq. Try +3/+6 shelving at 150.
