šŸ”¶ Tripowin X HBB Olina
Glad you’re enjoying them! I’d recommend trying Tanya filter mod before you try double mesh mod - it’s more of a hassle to remove two mesh filters than one haha. I’m using Tanya filter and don’t experience peaks, but I don’t listen at very high volume.
Tips are very subjective, but since you asked, I’ve settled on kbear07 as it gave me the best fit with medium bore. I’ve tried Azla SednaEarfitLight, Spinfit CP100, CP145, Aladdin stock tips, and either didn’t get a good seal or didn’t like the sound sig as much.
Found them, looking good. Never used foam tips and was considering for comfort. I have kindda small ears and canal. But when I use smaller tips, can’t get a good seal. When I use larger ones, they start to hurt. Are kbear 07s soft enough?
finding TANCHJIM T300 tips to be my go to so far Spinfits weren’t working for me on these
same thing with my tips experience on onlina, hard to find one that seals without hurting after a few hours. whith other iems such as fh3 i can put almost any tips and i get a perfect seal and comfort. so olina is not as bad as blon03 regading fit but it is not olina strong point.
Olina came in this morning!! :sunglasses:
I will be A/Bing them at low/mid/high listening levels to the Hana2021, Starfields, and ER2SE/XR to see who is the true king at $100.
Comparison out next week :wink:
Also I want to thank @hawaiibadboy for the amazing fit on these woww.
I’ve come a long way with a choice of proper tips for me, and found that Ackustune AET07 and it’s clones, KB EAR A07 or BGVP A07, bloated bass, so I damp it with foam inserts.
Right now I’m checking the funny silicone tips from Timeless, that one that looks like foam tips. Too much bass for me but provide a lot of fun and warm to sound.
Interesting! I found CP145 to add too much bass for my liking. YMMV right haha.
Hekili and Olina are my endgames. Olina on the Utws5 for working out, Hekili with the BTR5. Hekili for me a 10 and Olina an 8 or 8.5. Hekili so much better than the variations, my god. Also, Olina for the price is insane.
First off…where did you find the Hana 2021 for $100?
Oh, I’m just comparing the Hana for the heck of it. The $100 comparison will be mainly between the ER2SE/XR and Starfield/Aria. The Olina has been very great so far :slightly_smiling_face:
Tanya filter on nozzle (thanks to shortbus) and 1 Olina filter on front vent is even better…this iem is excellent for customization along with tips for various tastes with high quality driver. This mod is lean on warmer side which i like with improved note weight also male vocal is meatynow.
I am back to faaeal pure copper cable which is more transparant and also final e tips.
Many thanks to Chris and also the community for helping each other to extract best value according to their tastes…who is willing to mod tip roll etc.
Where can I buy tanya filter? :sob::sob::sob: I want to try these mods. Thank you in advance. I scared to buy the wrong filters
I saw a vendor sell them on aliexpress for about 9$ but has suspicions about if they were genuine so went with a brand new tanya instead which come with filters for 22$ (I paid 19$)
Thank you. I think I would buy one as well than just the filters <3
Also, how did the filters change olina? Thank you
I’m still expecting mine, but there are people who applied and shared their experiences above. From what I saw on the graphs, it is pretty similar to dual filter mod, but without the condensation issue. I saw some moisture at the perimeter of the nozzle after listening, say, half an hour. There wasn’t any issue with the sound but just wanted to be safe.
Easiest and actually the only way is to get Tanya. Tanya package is great to get as its wider bore tips are very good midcentric tips (elecom cap20).
The IEM itself is hit or miss.
@Nyanmin if in the US, watch Amazon. I kept checking over the course of a week and eventually found a seller for the Tan. Tanya. For $21, worth picking up the iem for the tips and filters alone.
What are some good budget eartips for olina?
I don’t know what qualifies as budget, the standard CP100 is probably one of the most popular tips here. I am a big fan of the Spinfit CP100+, which is just a different plastic ( I can usually get 2 pairs on Amazon for $9-12 ).
