Tube amp questions
So in the past few weeks i researched about a good OTL tube amp to match my 660s since i always heard Sennheisers sound very good on OTL amps.
My setup would be Foobar2000–>USB in XD-05–>3.5 out to rca into tube amp
i have 2 main questions:
  1. i mainly listen to metal, rock and some opera/classical, will a tube amp be worth for those genres?
  2. how will a tube amp change the sound? This is my main concern. I have fear that the more relaxed/less detailed approach of a tube amp won’t please me.
    So, how will the detail get affected? will i lose a significant amount of it? how will the bass/mids/treble response change?
    Also, how will changing the stock tubes to better ones (without spending a lot) improve the sound?
I know that it is difficoult to say how exactly a sound will change, especially when i’m considering a tube amp wich i don’t think anyone on here has heard of ( it will be either a TPAudio CF-4T-OTL (240 euros) or a CF-OTL 6080 (370 euors), those are well regared in Italy).
I would like at least to know what i’m getting into and if my purchase will make sense or not.
I’ll list the specs of the two amps if it can help:
CF-4T-OTL:
Ideal for headphones between 30 and 600 ohms
0.7 watts output
It uses 2 EC86 and 2 ECC88
CF-OTL 6080:
1.8 watts output
It uses 2 EC86 and 2 6AS7-6080
I’m not familiar with either model, but the build looks very nice for the price. It’s tricky to know how they will change the sound, especially when a change of tubes can make a huge difference. But that’s part of the fun if you enjoy it. If you really like the 660s off of a tube, I would suggest looking for a good price on a used HD600. They are a completely different headphone off of a tube
IMO, the tube sound is better on almost everything. My listening tastes are similar to what you describe; mostly just about every subgenre of rock and metal but sprinkle in some classical, EDM and even some hip-hop here and there.
The sound changes in ways I didn’t expect. The warmth does increase on tubes. I originally was worried about tubes because my ears are mid-sensitive and many products that had been described to me as “warm” sounded shouty or honky. Tubes actually smooth out the mids a bit and make them sound more natural to my ear. Overall tubes do sound smoother, but I don’t think I agree with those who say that translates to less detail. When listening really intently most of the details are still there on tubes, they’re just not as - for lack of better term - “finely pointed” as they can be on solid state. As in the details are all present, they’re just not as in-your-face as solid state can be.
Your Senn’s will also likely experience some frequency extension in both directions on a tube. My 6XX certainly do.
The biggest advantage I hear with tubes though is the “holographic” spatial presentation. The soundfield sounds more cohesive and full to my ears.
For context my tube experience includes a Loxjie P20, a cheap Chinese tube buffer with tone controls, and a Darkvoice for the last 10 days. On all three of those units I found tube rolling to higher quality tubes made noticeable, but not huge, improvements to the sound. The stock tubes on all that Chinese gear distorted the sound a bit too much and did sacrifice detail more than I wanted. However, still relatively inexpensive tube upgrades brought back a lot of the subtle details and also improved the spatial presentation.
It is really hard to give advice about an amp that I haven’t heard.
I have I owned a Loxjie P20, Schiit Vali 2 and an XDuoo TA-20. None did anything for me, but they were all hybrid.
My 'phones are pretty much all very efficient so I didn’t see any use in an OTL amp. I recently bought a low impedance amp and it is AMAZING! It transforms the HD600’s and the HD58X’s light up nicely.
It does not however like the Focals and is indifferent to the Fostex’s.
Every amp is different though. If you provide all the specs and tubes maybe someone here can give you better advice.
As of right now i am interested in just the amp. If i’ll decide to buy it, i’ll defenitely get a used 600 in the future just to try it.
Thanks for the help, what you are describing seems to be what i am looking for.
This would be very interesting to hear.
Yeah i read that the cheper model (CF-4T-OTL) had some grain to it, where a tube swap would very much improve it making less grainy, but this was from a thread from 2012.
From what i know the quality of the amps has been improving over the years, so i hope i will not find this grain.
You are right, i’ll list the specs of the two amps.
I’m a bit late to this, but maybe this could prove useful to others: I understand several experienced audio engineers have argued convincingly and proved practically that “tube sound” can be 100% reproduced with solid-state gear or with DSP. With that in mind, testing “tube sound” for yourself could be as simple and cheap as using:
  • the foobar2000 plugin foo_dsp_tube
  • the SPL Twin Tube VST plugin in whatever player you can get that supports VSTs (including foobar)
  • the Tube Sound Simulator function in ViPER4Android (and ViPER4Windows, apparently), which is supposed to emulate the output characteristics of a 6NJ1 tube
  • or listening to comparative sound demos of tube vs. SS amplifiers, for example the one from our very own Zeos: https://www.youtube.com/watch?v=OeNFZEMSRVc.
Now I’ve never actually heard a tube amplifier, so I can’t vouch for any of those plugins, but maybe others who have could make the comparison and let us know how close they are to the real thing.
Personally i am not really a big fan of DSPs, but since it doesn’t cost nothing to try it out, i’ll check it out. Thanks for the suggestion.
budget is 1500 i already have these tubes PSVANE CV181-T MKII (6SN7) PSVANE 6SN7 -BE blue globe SYLVANIA 6X5GT 2 of each matched
I want a balenced tube amp the these tubes will work in and i want the amp to be push pull ,balanced with xlr out ,and class A . for my sennheisser hd800s this will be my first tube amp
