Ok So I’m putting this here since I guess it applies to alot of different Amps, Pre-Amps, Power Amps, DACs, etc.
Kinda curious on other people’s takes on Driver Tubes, specifically 6SN7 and 12AU7/ECC82, plus any close enough equivalent, even things like using Dual tube Adapters like 6J5 + 6J5 to 6SN7. EDIT: Also Added 6AS7/6080 Since those are pretty common too, so a Power Tube section has been added for this list too.
I’m building my own amp based around the 6SN7 and the 12AU7 as Drivers (And as Shunt Regulators, although the tube used there doesn’t have to be such a high quality tube honestly), so kinda curious as to see if there are any recommendations.
Oh Also heater current of the driver is a non-issue in this case, so recommend things with higher heater current like the Mullard CV181
Also for anyone who owns a Darkvoice, Lyr, Crack, Crackatwoa, etc, this might help you explore new options. Stuff like 6CG7 to replace a 6SN7 or 6922, I just want opinions on the tubes you guys have used, maybe I can compile a list and put it here to help any tube newcomers that want to know what they can stick into their Amp safely.
EDIT: Added New Portion involving tubes based off of the 6AS7/6080, the more amount of tube data that can be documented for the ease of use of everyone else, the better.
I mean you can search up datasheets but It’ll help quite a bit if an extensive list was made for this kind of thing with all the tube types gathered in One Place (kinda like this one: https://www.head-fi.org/threads/for-6as7g-tube-rollers-here.410326/) but maybe a bit more towards electrical values since the amp circuit also plays heavily on how a tube will act/sound, although usually there are constant characteristics that a tube tends to retain regardless of a circuit.
Still for the actual discussion, reference sound and the amp used, but if possible (although not necessary, I can eventually Search It up if I have the tube Name) add electrical values (Heater Current, Plate Resistance/Current/Voltage, Gain, and Transconductance).
