Looking to turn my KZ ZAX into TWS. Any advise on a good bluetooth ear hook for the Linsoul KZ ZAX?
Either the KZ AZ09 (there is the pro but i havent tried it myself) or the TRN BT30. Personally i like the KZ better, smaller case and overall better form and its dirt cheap.
You could go for the FIIO TWS 3, but its pricer and you will need an adapter (since getting the 2 pin version is pretty much impossible
Do you have the KZ AZ09? The common concern around it is that there is a humming noise from the pair?
Ya i do. I dont hear any humming on my pair (using the Legacy 3)
