Hi all,
So I received my e10k and everything works fine ! Volume is much louder, and everything sounds better.
I’m happy with it. Just got one question, what is a good sound program/software (if I’m naming it right) to tweak my sound settings?
Hi all,
Peace apo.
I do not recommend doing this with tygr it doesn’t respond well at all to changes to its signature. Not sure what your expecting to change but it also will require more amp power to change it
Thanks for your reply, I will skip it.
Running MSI gear you should be able to try Nahimic. Quite a badass for gaming.
