Upgrade for DALI Zensor 3
They are a lovely speakers, the Dali Zensor 3s, but since I watch way too many Z Reviews I got interested buying something better. With budget up too around 500-600 usd
Klipcsh RP600M is the obvious choice but are there any other options? Powered speakers is not an option since from time to time I use 5.1 receiver with those speakers for surround, usually have them in stereo. (if im not mistaken - can you use powered monitors with 5.1 surround receiver ? If receiver has pre-outs it should work?)
yes it should work
I also had the Klipsch RP600M on the list for 2.1 Setup in our living room. What about KEF Q300/350?we use the Q300 as desktop solution with an subwoofer from our old 7.1 reciever. Very nice imaging. Good sweet spot. Frontport makes it easier with placement…
KEFs sure are pretty :stuck_out_tongue:
THESE B&W 607 review | What Hi-Fi? are also in the running. I hope Zeos gets some B&W at some point, would be a great review.
another save bet are the ELAC Debut B6.2- nothing special but do everything good for the price and also have a frontport
