My trusty and dearly beloved MH752’s have broken after a 1.5 years off use to a faulty right cup problem. I really loved to use these with the Vmoda Boom Pro. I used them for both PC and PS5. For the PS5 I had them hooked up to a Turtle Beach DSS2 to get audio from my PC at the same time.
Neverthess, I am looking to upgrade. Budget isn’t a big concern. I would preferably like something that is compatible with the vmoda boom pro and doesn’t look too gamery/cheap. Detachable Mics are a huge bonus!
I have M40xs that I use as backup, but they are pretty uncomfortable.
At the same time if you have any dac/amp recommendations that can be used with the PC/PS5 and also take audio input that would be cool.
Thanks
