Hello,
I am trying to find cable from USB A to USB B but with 90° degree angle. Something like this:
The one on my link costs around 3usd so I am trying to find a better quality.
Do you have any idea where to buy this?
Best regards,
Becis
Hello,
Best regards,
Becis
The 3usd version does not work or cuts data?
These must be better since price is 5 times more. Also lot’s of colors.
They also * AUDIO OPTIMIZED the cable so music must be prioritized?
Well least they shielded it with chokes.
It does work and I am using it right now, but I have combo Schiit Asgard 3 + Verum 1 and the whole setup costs around 700 usd.
So I have just the feeling that I would like to use in this better cable or it does not matter?
Unfortunately the one on your link has wrong orientation, so the cable would be going to the ceiling
so I cant use it.
Yea, Schit audio doesn’t know that the port is side(wrong)ways.
I think the cable you are looking would be USB 2.0 A to Up Angle B Cable, so it would “go in right ways” with Asgard. Mostly they seem to be “printer cables” and i would think there is no “audio / hifi” grade Up angle A>B cables.
China market seems to have plenty but as mentioned. They probably not any better than what you have.
I’m actually using a couple of those, they were actually a little better on a certain device I used to have that was very picky about how long the cable you plugged into it was before it failed to function. Audibly, it did nothing but I liked the colors for tracing cables.
