I need a USB-powered (preferably Type C) DAC/amp that supports left/right balance in Windows.
It’s really frustrating that almost no manufacturer states if they support L/R balance. For example, AQ Dragonfly does not. God knows why not. It’s a critical accessibility feature for those with some hearing loss in one ear. Mine is only a few dB but it’s enough to throw off imaging.
Ideas appreciated. My desktop amp is a THX AAA 789 but I need something for my laptop, mostly to use with Mangird Tea IEMs.
as far as i know there arent any modern combo unit (or even regular ones) that have balance control, the only modern ones I know of are tubes (like the Xduoo 604)
might be a dumb question but why do you need the balance control?
One would think. Windows balance support is not needed if a proper DAC/AMP would have channel balance instead. There are plenty of options if power plug is an option.
Maybe even sell THX and replace it with one unit operation.
Folks, I said “supports left/right balance in Windows”, not “has a balance knob”. I just need to be able to adjust the balance in the Windows sound control panel. Believe it or not, a lot of DACs don’t support this feature that you would think would work on any unit. Like the example I gave, the AQ Dragonfly series has no balance adjustment.
I don’t need something with knobs, I just need a very portable USB-C DAC for a laptop that supports balance adjustment in Windows.
The iFi hip dac v1 supports L/R balance in the Windows sound control panel. Not sure if the new v2 version supports as well, but I would assume yes. Input is a USB 3.0 type A. Comes with a type A to B cable, but I also purchased type A to C for us with my Galaxy S8. Charging port is separate and is type C
