can’t find a damn thing anywhere, please help. I need something that fits the FiiO M3K;
if the M3K has a case of some sort you could use a solution like this
Just slide the thin metal piece in between the DAP and case or stick it to the case and it will easily hold a dap where ever you put the magnetic base. you could also attach the metal piece to the dap if it does not have a case, but I don’t personally like doing that.
alright i’ll look into it, i just need it to stay together on tulsa highways in a pickup truck doing deliveries
the player will rarely if ever leave the truck so double sided taping a plate to the back of it won’t bother me
this is what I found:
You shouldn’t need extra plates or even double sided tape. They come with at least 1 plate and double sided tape pre applied. (Well at least mine that I linked did). If you don’t mind the plate stuck to it, then it should work great. I don’t like the look and I can also take my phone out of its case so I can magnetically charge it. The plate interferes with that. Though my current phone doesn’t have the magnetic charging so for it mainly is just looks.
there are issues with the pre applied adhesive and i will need to stick a plate to the dap anyways, i will check if it comes with a plate tho
-it comes with a plate, won’t be buying the plates
