I try to run a vst plugin via Foobar 2000
the plugin I want to use is SPL TwinTube
installed George Yohng´s “VST wrapper”
activated the vst wrapper in the playlist dsp menue in foobar 2k
added in the vst wrapper both folders - first for foobar and second for the SPL Twin Tube
I can´t choose the SPL Twin Tube plugin in the tray icon menue of vst wrapper
So I have had issues with vst running nicely in foobar as well, and I just use a daw with foobar being routed in through asio and routed out to the dac
thank you for the link - your chain sounds quite complicated
which DAW is it foobar being routed through?
have googled the last hours a bit and I will try some other vst hosts after office
asked the friend of my wifes sister and he comes over, if I won´t get it running
he produces music since the 80s or so and knows the plugin stuff front and back
Cool, he should be able to help. I use mainly 3 daws for mastering (that I also use for vst hosting sometimes lol), that being steinberg wavelab, steinberg cubase, and magix sequoia depending on the project
my wife wanted for years a mac and I told her I hate the closed iOS … since audio became more important to me, I see my mind changing from time to time
a mac mini or a macbook air would make some things much easier
I still use Windows for all my audio stuff, you just have to spec out a PC for that to give you the best stability and reliability. Mac does not necessarily perform better per say it just happens to be a little more reliable when it comes to audio
Well there are certain motherboards, graphics cards, drivers, and more that handle audio work a bit better, and also play better with some interfaces. You don’t need to do this, but you do want to make sure you have less issues if you are recording anything critical
By handle better I mainly mean lower interference with audio, less latency impact, and more stable drivers with a lower chance of conflicting with other drivers
