Warm Amp to drive DT1990 Pro
Hey M0N, reviving this question again.Sadly, The Xduoo is now out of stock.
So, I’m back to that point between buying the DX3 Pro, and importing a Liquid Spark later in for arround 2p0 dollars. Or buying the K5 Pro for 150 Euros in the UK.
But now I have one more option. I have raised the budget to 350 dollars for DAC and AMP to see if I could find some more alternatives. And I seems like the SNSL SP200 THX AAA 888 is 295 Euros, and available in France. I was thinking of buying it and a cheap DAC (upgrading later). That way I would future proof my setup, and I think it may be a very good (and powerful) AMP for all my future headphones.
I wanted to know what do you think of that SP200 choice, and if you have any other recommendations in that 300-350 dollar budget.
Also, if I go for the Fiio K5 Pro, I would have to wait about 10 days after I get the DT1990 to buy it (because I will go to UK only arround the ending of my trip) and I wanted to know if my Fiio A3 can drive the DT1990 until I get the other amp. Thanks!
This would be pretty good, gives you lots of options but costs more
That amp is bright/analytical leaning FYI if you are still looking for a warmer amp, but it is a solid offering
I think the fiio a3 would work for the time being if you go with that
Ok, thanks!
I know the DX3 is Brighter and the SMSL is also bright/analytical
But how do the Fiio K5 compare?
Also, is the SMSL less bright than the DX3?
I think the k5 pro is a bit more balanced than the dx3.
I think the thx is more aggressive than the dx3 and both are somewhat similar in brightness
