suggestions at price points up to $500? by good I mean don’t suffer from simple flaws like compression and such. so don’t just name options just because they’re combo. validate your submissions with why you think they fit into the ‘good’ for more than just ‘price to performance’. what performance makes them stand out to more expensive options?
It’s $100 more, but if you ever plan on adding speakers or a turntable I can’t recommend the Sprout 100 enough. I wish I had gotten one sooner, as I end up using the headphone out as much as I do on my better sources. The Chord Mojo is awesome as well for $379
I started with the Massdrop CTH + SDAC and it’s garbage compared to the Sprout. Even if I never added speakers to it, it would have the better choice for me
The only issue for Marzipan is that there isn’t preouts, but you could always just get a monitor control like the Mackie big knob passive or jbl nano patch +
Yeah, it’s not an insurmountable problem. In the end I guess there’s always going to be some compromise. I’d have to go back and read the details again but I thought that pre or line was one of the things you could program as one of the numerous options. Like you said worst case and big knob solves that.
I think you can turn the inputs into outputs but I don’t know if you could set it as an active variable control for powered monitors (you might but I can’t remember)
I am in need of xmas gift ideas so I figured I would ask for a dac/amp I am kind of interested in getting items to chain together. What would be good for dac/amp/tube amp, each with a range of $100-150 each?
Hmm, you could get a fiio k5 pro and then line out to a schiit vali or a little dot mk2
If you wanted separate components, a topping d10 or smsl m100 for the dac, a monolith liquid spark for the amp, and a little dot mk2 or vali to for the tube
I’m a big fan of my iFi Micro Black Label. I know it’s going to be near the cut off for the OP budget wise, but if you wait until black Friday you can find some great deals.
I have mine hooked up to my desktop PC at home and seldom take it anywhere. I’ve had a few other set ups the last couple of years. I just really like the sound (obviously), and the fact that it takes up so little space on my desk.
