Going to buy a magni hersey or an archel 2.5pro what dac what would be a good pairing for these amps for under 200?
So personally I quite like the topping e30 with the heresy imo, but if you go for an archel 2.5 pro you might as well go for the enog 2 pro imo
was thinking the same thing, would you personally go for the hersey or the archel
What headphones are you going to be using with it?
hd58x, dt1990 pro, don’t want to upgrade to much in the future. Also Sundara
also sundara’s forgot to mention
Gotcha, so I think if you wanted to go for something neutral borderline analytical, the archel 2.5 pro + enog 2 pro would be my pick, should be nice.
I think personally you might actually like the asgard 3 imo, as that would give more impact to the sundara, and better control the treble of the 1990 pro, and you could go with a dac like the earmen donald dac imo
thx for the advice i think i know what i’m going to buy.
