Nice looking PC case.
You should teach cable management classes
^I second that.
Can’t take pictures yet, but I just bought:
  • Schiit Sys
  • Schiit Magni 3+
  • Schiit Modi multibit
Glad to see you got it all figured out with your limitations at play. :+1:
Pricey little combo, but Nice.
Welcome to the club, VERY curious of what you think of it!
Enog2 Pro and Erish arrived today from @Pr3ssAltF4. Everything looks as described. Haven’t used it yet, but just got it all set up. I might add a photo later, depends on if I can get a decent photo or not.
Got it all working and figured out everything except for how to change the led light colors on the erish. The Enog2 Pro doesn’t have that function does it? I’ll also have to adjust the wires in the front so I can reach the volume knob easier.
On the erish you quickly press the power on button for the light change, instead of pressing and holding it to power on and off. The enog doesn’t have that function. Do you know about the 3 different output gains on the enog2?
Yes I know about that function on the enog and got it figured out, put it on the middle option for now. It may be too bright right now for me to see the led colors. I see lights change inside but it doesn’t really show up.
Maybe because of the ORANGE? @Pr3ssAltF4 middle options seems the best in my experience.
Just played a game with the right and left channel switched and it was so bizarre hearing everyone in front of me coming from behind me. I think I need to swap the xlr cables as I didn’t know if it mattered which was left and right or which one was left and right as I didn’t really see an indicator. Do I have to unplug the Enog2 Pro to power it off?
Ok, swapping xlrs didn’t do it. So, someone please help me figure out why the channels are switched, we can talk about it in another topic as to not clog this one up if you want.
Edit: I guess I can just swap the left and right on the cable to the headphones, but I had it worked fine on my setup the other way around before, so it seems weird to need to swap it now. Maybe I had the rca cable the opposite way it needed to be prior?
Make sure to look carefully as the xlr don’t match in a stack format
And the enog2 doesnt have a power off, I just keep mine on all the time
Ok, that 100% explains it, thanks for the info.
Wishy case could fit the noctua cooler so I didn’t have to cancel my order.
That looks great! Nice job! Especially for the price!
I’ve mounted it before and it’s definitely better than the dark rock pro 3 but unlike noctua I still have to take my mobo out of my case and install it that way which with my pretty loaded build fan wise as well as storage wise … with my fat fingers isn’t very fun especially plugging in my 8 pin through fat vrm heatsinks and now a fatter cooler. It’s gonna be about 30 minutes of to an hour of suffering as much as I love building other people’s computers I hate rebuilding my own even though most of it is already pre done. But I might fuck around for about attempting to mount it in the case until I give up an hour later and 6 attempts I have a ton of thermal paste to waste.
Today I got a big, stinky yellow tape-brick from China:
With this inside…
The A90 is one option for driving my Susvara (heard from someone that owns one that it works) as well as to try with 600-ohm Beyers. The D90 will go to my wife’s stack, replacing the Dx7s as her DAC.
