the ‘best buy’ thread made me think about what you would have to buy to get better sound than the Massdrop can’s. it’s likely a lot more than several of them cost…so share your thoughts / opinions.
the real winners, from what I’ve read and experienced, are these four:
HE-4xx @ $180
HD58x @ $160
HD6xx @ $220
Elex @ $700
What do you have to buy to get markedly better? not just a bit better…markedly better, so it’s an obvious / audible upgrade.
yes yes, everything is subjective…but the above 4 have been defined as good, really good, especially for their price.
so what else has been defined as really good that beats these? you can be brand agnostic…it doesn’t have to be HFM beating HFM or Senn beating Senn or Focal beating Focal.
I guess this is just another exercise to surf out the other outliers.
I think if I were to do a fair brand comparison, it’s going to be direct upgrades from the same brand (direct enough lol). I think you would have to move up to the clear for focal, the arya for hifiman (as I think the ananda vs edition xx is more preference than technical ability), the HD660s to beat out the 58x but I think the 6xx really doesn’t have a direct upgrade in sennheiser, and for the 4xx, I think you would have to jump to the sundara or he560v1
HD-600’s made more than 4 years ago used with a new Senn pad and decent cable are really good for classical. $300 or a bit more with the new pieces and used 600
and its not just me, but not a fan of the Elex @ $700, a used Clear can be had for $800-850 and is well better IMO.
I mean it’s got a more neutral signature and also is a bit more detailed and technically proficient. I think some people may prefer the elex though because of it’s more fun signature
I wanted the Pros when I got mine because I liked the color scheme more, but the standard version has grown on me. It really stands out from my other (mostly black) headphones.
Mon I just saw Zeos review on the Clears and it really doesnt look good. He even said they where the french beats. He said they dont have as much detail as the Elex. Are you sure these are better than the Elex?
Yeah, z’s review of the clears is not that accurate imo. Not every review he makes is going to properly represent a headphone (that goes for all reviews lol)
