So I decided to buy a pair of Martin Logan 15s refurbished and now I will need a suitable amp and suggestions for that would be great!
I currently have SMSL SA-50 powering my Micca MB42Xs
see my post in the other thread, added some amp recs Looking to upgrade. What should I upgrade first?
Not sure if I want class A or AB any advice would be great on that as well
It’s the wrong question, a well designed class B amp should sound just as good as a class A amp. class A amps can’t have crossover distortion, but they fundamentally amplify the same way.
Just forget about topology and worry about how they sound.
If anyone stumbles upon this and is wondering what I ended up with I got a Emotiva Bas-X a100 for now bc its affordable and I already blew a lot of my budget on the speakers
The Atoll se 80 is a good amp but a bit expensiv.
Otherwise the Denon pma 600 or the pma 800 ne.
