I’m loving them…and yes, they sound better than the wired. my only complaint is their clamp is a lot tighter than I’d prefer, so I hope use on my fat head stretches them out and eases that over time.
have you done any pad swapping, with the Yaxi’s or anything else?
yeh, the clamp is pretty clampy. as for pads…I would think you would just force a Yaxi made for the Porta Pro as it will eventually conform appropriately. though I seem to recall some saying to cut out the center bit of the foam pad on the KPH30 helps too.
