Hello,
I’m currently interested in buying a wireless headset but Im not certain on which one to buy. Since there a options as the G pro x wireless, Sennheiser gsp 370 and the arctis pro. Has someone tried them out or knows which one of these has the best value?
Does it have to be a gaming headset? They aren’t particular the best for sound. If anything I would tell you skip the Logitech as it’s pretty awful in my opinion. GSP from sennheiser are alright not the best though. Arctis over there would be better than the other two because of better imaging and the equalizers. Also we now have MH670 which isn’t bad and is a bit of a cheap option with a good enough signature.
Granted I wouldn’t say any of these are better than something such as a SHP9500(or about 95% of headphones in general) with an attached V-moda boom pro running ampless
I currently use the shp9500 with a modmic 5. However I’m kinda turned on by wireless and the shps are also too bright for the music I listen to.
Gotcha, yeah I would say arctis then would be alright. You can go turn the shp9500 wireless though with a built in mic on that wireless but also change the pads to something else that can dial back that brightness or use some equalization
Can you share a link or something on how to turn the shps wireless? sounds interesting
Sure I saw zeos do it himself in one of his videos. You see him use it and mention it here https://www.youtube.com/watch?v=hay6yixijKY as any headphone with a 3.5mm jack can use this.
This is the one he uses https://www.amazon.com/Mpow-Bluetooth-Transmitter-Headphones-Hands-free/dp/B01KXIKCSI/ref=as_li_ss_tl?s=electronics&ie=UTF8&qid=1508329188&sr=1-5&keywords=mpow+bluetooth&linkCode=sl1&tag=zeos-20&linkId=99e5b23c007acd4bad9b10fd5921f4f5 but there is quite a few alternatives out there just takes a bit of searching and a bluetooth receiver for the pc if I remember right.
