I’ve come to the conclusion that my ears are broken. I genuinely rate the Sony’s. Even above the Bose.
I wouldn’t say your ears are broken lol, it’s just preference, people hear differently
which Sony do you speak of AL?
Sony wh-1000xm2
Bought it with the intention to commute with daily. Ended up listening to it at the office. With LDAC it actually sounds pretty decent to me,
the XM2 and the XM3 are known to have better sound than the Bose. Bose has the best ANC…but their sound is rather meh.
Bose does have that comfort factor. Bose I find to be a lot more comfortable than the sonys.
But I’m in the club who rates the sonys better than the qc35
I just really like the noise canceling on the qc35s, so that’s why I still keep them around. I do think the sonys sound better though. But I think some well fitting in ears can do just as well as the Bose when blocking out noise
If I still needed ANC on the regular basis, I would definitely try the Sony.
You can try Creative Aurvana Live. A closed easy to drive ‘‘sleeper’’ headphone ![]()
Koss will not isolate at all. I have them at work and I can have normal conversations with people without put them off.
The Cal’s are pretty good and portable, but I would be concerned about the durability of the build which is on the cheaper side
Yeah I just bought them, time will show. Nothing special on the built side for sure though.
But the sound is pretty impressive for the price for sure ![]()
Couldn’t agree more, dat bassss
I currently use a pair of cheap Sony on-ear (xb550), they are bass heavy and ok comfort. But I was thinking on upgrade to a Sivga, either 06 or 02. Any comments regarding then?
