Hi gang! Looking for some headphones to take with me to work to use on breaks. I work in a loud factory. I currently use Meze Noir’s and they sound great. Easy to drive off of my phone. I am just getting tired of lugging a full on pair of headphones to work.
So I have been looking at the koss porta pro’s as an alternative. Much smaller and more compact. Anyone have experience using these? I know they are not noise cancelling, but wondering how noise reducing they are. Even outside on break it is rather loud near the factory.
So wondering if I should try them or an alternative like them. Can not do IEM’s they are uncomfortable to my ears and the close spl lv’s cause me pain over time.
I have given up on anything that sounds “great”. But i think the koss’s or something similar may be good enough to still enjoy some music on breaks.
Great sounding little phones, the build’s not super robust but they’re as cheap as chips as we say in the UK…Amazon? then try and send them back if you don’t like
being they want to get away from the bulk of headphones, the QC35II’s aren’t really a solution. IEM’s or the Koss KPH30i or KSC75 would be though, but then you still have the issue of lack of isolation.
there is a M50xBT…but I’ve not heard anything about it sounding better than the M50x.
you could also look at the Sennheiser HD4.40Bt or HD4.50Bt if you want ANC. they’re portable and fold up. I’ve got em and they’re decent for something so inexpensive.
I would take the QC25 or QC35 over the M50 any day. More comfortable. More portable. Better isolation. Better sound. Better quality. I used to like the M50 until I got the QC25 and promptly threw them away.
These days I’m using 99 Noir or Dekoni Blue because I’m in a quieter office, but if I was battling a noisy environment, QC25/35 for sure.
