šŸ”· xDuoo MT-602
I didn’t mean to say the MT-602 is the only great cheap hybrid :stuck_out_tongue:
I have no experience with the T6Pro but on first glance it looks like a good competitor to the MT-602!
Tight right, I should have replied to the OP :slight_smile:
the mt602 is class a the aiyima is class d.
edit: they wont sound the same. class a and class d sound different in the bargain realm.
From what I can tell the MT-602 has a class A buffer; which is not the same as a class A amplifier…
Based on the heat it generates and power it drows (none and very little) I’d be extremely surprised if there was a fully class A amp in that little box…
Thanks for your replies - much appreciated! I’ve set some guidelines as I traverse more into the hobby lol
  1. Spend as little as I can
  2. No more than $300 for a single piece of gear
On Reverb there’s an Mt-602 going for $60. I might just negotiate for lower or wait till Black Friday for deals. My first thought after the OTL suggestion was the Xduoo Ta-26. I will slowly view all the options I have new or used. I thank you all for the time you’ve given to me 8^)
I mean, all things considered - $60 for an MT-602 is awesome and I love that little amp. Was just trying to push the possibilities and temper expectations in regards to ā€œtube effectā€. Grab one to play with for sure.
aiyama makes a nice bluetooth pre-amp as well. i have 1 in 1 of my systems.
$60 for an MT-602 is an amazing deal and it’s definitly pretty tubey :wink:
I’ve put in some Sylvania 6AK5’s from the 50’s and good god does it sound warm and mellow and honey-textured :stuck_out_tongue:
Hello, I am currently using the MT-602 as my primary headphone amp. It as driven my headphones with out having to turn the dial past 10 o’clock, but my hardest to drive headphones are 80-ohm/96db (DT 770) My inner geek really likes the Idea of getting a set of Fostex T50RP and tinkering with them to Taylor the sound to my liking. What I don’t want is to go down a rabbit-hole of expenditure on amps to power them. Has anyone used the MT 602 with T50RPs and found the power to be sufficient… or not?
