šŸ”· xDuoo MT-604
Listening 604 and P1’s to this…
Sounds dope to me, detail, speed, precision but with a bigger soundstage and better bass compared to just the DX300 Amp12…that’s a cheap synergy flip :upside_down_face:
You shouldn’t need matched as you have 2 channel gain adjustment :+1:
4.4 IEMatc? Can’t confirm or deny outside of the fact we know how much you guys want it :slight_smile:
Looking forward to then :wink:
How about a big chonking 4 pin xlr iematch? Lol. Just thinking about the size seems ridiculous but I bet theres people that would need it I suppose.
are all…
Really 4.4 is the audio interface king..no big ass xlr connectors, no 2.5mm busted stuff..simples :man_shrugging:
"Tone2 Pro keeps getting better and better. Firmware v1.30 is out.
  • Added the pre-amp feature (when enabled, line-out volume is controlled by the volume knob)
  • Added LED indicator lights for pre-amp (3 green lights)
  • Added a feature in which the volume gradually increases from zero on startup
Now it acts as a pre-amp and lets you control the volume also in line-out mode. This made xDuoo MT-604 the perfect headphone AMP for IEMs with 2 stage volume control (volume is controlled on both devices)."
I think MT-604 can be used perfectly for IEMs, this is how I managed it.
Yeah I wish my soloist had 4.4 sometimes but everytime I have an accident and yank my headphones standing up or walking 3 feet away from my desk to open or close my window I’m glad I’m plugged in with a 4 pin xlr. 4.4 would never put up with the clumsy everyday use that 4 pin xlr does. It’s not even debatable. It’s far more robust. Mobile wise 2.5 needs to die and 4.4 isn’t some kind of major size increase that warrants keeping those fragile ass 2.5 connections.
Now owning a ZEN DAC V2 and an A90 (different chains) I have to agree with this take…
…and what sets do you find ā€œcan be used perfectly for IEM useā€?..troll we won’t do :man_shrugging:
What do you mean? What troll?
Your channel hype :wink: so what sets are you running from your 604 before I get bored :sleeping:
Having trouble understanding you, what is channel hype? Are you talking about my blog?
Yeah me too bro :wink:
I wish the 4.4 Pentaconn was being rolled out to more balanced systems as the default balanced connector, and I’m pretty sure we will see that in the near future. But until then… I like my big ol’ XLR connectors. That is all you see in my system. No issues with them here.
I can see me picking up one of these little MT-604 gems as a preamp someday. I like it!
OK guys i’m getting an earth type hum with this amp, not audible when playing but when not very much yes…touch the amp and it goes away one anyone @MazeFrame got any idea how to sort this please? :pray:
:beers:
Since touching it makes it go away, I would try grounding the amp to, well, ground.
A simple kit with a ground wall adapter and one clamp should be enough.
Or you bend open an old coathanger and stick some tinfoil in some slit or under some screw…
Cool thanks for the reply buddy :beers: just two more things…would this work it’s UK over here
https://smile.amazon.co.uk/Standard-Grounding-Earthing-Pillowcase-Resistance/dp/B08TM1M53Y/ref=sr_1_3?dchild=1&keywords=Grounding+plug&qid=1634129719&qsid=261-7140206-8949460&sr=8-3&sres=B08TM1M53Y%2CB08QRBBG9P%2CB07S2PPQWF%2CB005NZB5GK%2CB08G3D3TKD%2CB08JLN4JBX%2CB08JHS7B2N%2CB094ZQG2GP%2CB091777DW7%2CB08G3JRRTL%2CB07W71HM7R%2CB092LF55ZP%2CB000I2JX3A%2CB07KT9J57K%2CB08TLY2BJX%2CB092S5MXTF😃 and two why is it doing it :man_shrugging:
You need to somehow attach a ground to the device.
Since it has balanced input, check one thing: What happens when you touch the source device (DAC?) while nothing is playing?
If this makes the hum go away, it is a floating ground problem (= something a little ground wire can fix). Else it is something else and you should wait throwing money out for a ground strap.
When I am correct with my theory, the ground of your entire hifi chain is separated from earth (= no electrical connection between ground and earth).
Since transformers are subject to the laws of physics, they capacitively couple a little voltage from the power grid to the device side. When that voltage difference can’t even out, you now have voltage rising and falling in respect to earth at 50 (or 60) Hz.
Thanks buddy I’ll check out what you’ve advised…I haven’t got time today but I’m on it :beers:
