Interested to see what are some solid head units or dsp processors
I’m an amateur tournament bass fisherman and I like music. I like to listen to music while I fish.
This combination sounds really, really good in my BassCat Puma.
https://www.crutchfield.com/p_158M100BT/Sony-MEX-M100BT.html
The class D amps in the head unit are phenomenal. They drive the infinity 6x9s really well. No need for a separate amp IMHO, and I could still add two more speakers (Infinity Marine) to the mix if I wanted. People comment on how good my setup sounds all the time. Crystal clear, full range with zero distortion while running as loud as folks on the my boat can tolerate. The speaks are mounted in the gunnels, which makes them sound like they are in large sealed enclosures. Can’t recommend these enough!
I stream all kinds of music into this setup from Spotify. The Sony Music Center Application that controls all this is actually pretty good once you get used to it.
I’m using the mosconi 6to8 pro, it gives you all the option you can think of and I would say a dsp is the most important thing to get good audio in a car.
