Your preferred IEM connection
QDC 2 pin 0.78 definitely .
I’ve had way too many problems with 2-pin breaking on me. I get it’s what most of the market uses… I’ve just had way too many problems. I’ve had pins break, and the molded plastic around the pins break away around them with normal use.
Nothing beats the stability of KZ Type C connectors.
MMCX for me, it allows the IEM and cable to rotate and adjust to the final fit to my ears, plus its durable and reliable, more so if you dont change cables (change the IEM if you don’t like its sound), 2 pin style are intrusive, tension build up, prone to corrosion and break easily. MMCX is hands down the winner !
