Zen DAC or Stack?
I am currently using a IFI ZEN DAC to power my HIFIman Sundara i have it plugged up via a custom hart audio cables 4.4 pentaconn connection plugged into the balanced output on the zen dac. I am just trying to get the best out of these headphones as i can. Would i be better off with staying with my zen dac or getting a schiit stack or atom stack with non balanced output?? willing to spend 350$ to get the most out of my headphones thanks for reading
welcome to HFG!
the Zen DAC is my daily driver for my Nighthawk Carbon’s, also on the balanced output. they’re awesome!
that said, audio is a journey, so if you want to try something else for the sake of something else, go for it. however, I would say try other headphones first as the Zen DAC is well regarded. perhaps buy the optional power supply, like I did.
thanks its good to be here, and yes audio is a journey I started out with a pair of sennheiser 598hd SE with a schiit fulla 3 then moved on to my current setup the Sundara with IFI ZEN DAC
Now i only bought the ZEN DAC after watching the video review by zreviews and considering it was better than the fulla 3 and the fact that it was a AMP and DAC in one unit.
I did not actually think about buying the power supply as it was able to just to run off PC power thanks for your input.
hey just wanted to give you an update i bought the 5v power brick in december and as of writing this today my zen dac appears to be broken.
when i plug my head phones into the balanced or unbalanced port i get crazy loud noises constantly i thought it was my cable tried another one and still did same thing, thought it might be my headphones so tried another pair and still same problem i even tried running the unit off of usb like i did before and still the same sound problem…
i’m not sure what happened but i think my unit is dead for output audio.
did you disconnect the power and see what happened when just hooked up via USB?
that was the last thing i did; i thought it was cable at first so i replaced it with another and still got the noises. Then i thought it might be my headphones going bad so i tried with a different pair and still the same noise then of course as a last result i unplugged the power source and tried just usb like i was using before and still the same noises.
i put in a support ticket with ifi so we will see what happens.
