šŸ”· ZMF Eikon
Yes. They are almost completely closed imo. The isolation stuff is due to a lack of squeeze. They feel almost feather like in tightness of fit, even though they are pretty secure. Keep in mind though, mine are used, so whoever had them before might have had a bigger noggin.
I would say these will comfortably keep you in your own headspace anywhere except a construction site or if someone is playing drums in the room though. Everything that’s not music is very muted.
There is a complete seal around my ear. The vents don’t seem to let sound out at all unless it’s realllllllly blasting.
Edit : sorry I read that wrong initially lol
if you want/need more clamp you can bend the headband to accommodate. Zach put out a video showing all the different ways to tweak the fit of the band
Yep, have seen that and I will likely adjust it. At the same time, the lightness of the clamping is nice. I kinda just forget they’re there.
Sidenote : Whoever thinks these things are heavy reallllly needs to do some bare minimum shoulder / neck / back work. These things are pretty damn light, especially for having wood cups. After reading everything I expected something like a brick.
i mean they are heavy in comparison to some cans, but the headband and strap system zmf employs is the secret sauce. it just does such a good job of distributing the weight evenly and combined with the awesome ear pads make them super comfy as long as you tweak the band for your head specifically.
Hahah, the ifi hip dac is special though. I’ve been using it on my laptop or lg v20/starfield instead of the atom/enog/xbox/starfields and im starting to like it more. But the 712 and darkvoice is better overall. I’m excited to get a zmf though. Thanks for all info though. Leaning towards the eikon.
listening to my Eikon right now through foobar > enog2pro > hagerman tuba with the RCA 7189 tubes rolled in. Sounds amazing. I’ve been exclusively listening to LCD-X for the last 2-3 weeks and I can really pick up on the differences here. This sounds just so pleasurable lol
I think my only complaint is gonna be I can’t seem to get these guys’ headband to comfortably clamp on my head. I watched the headband bending tutorial and spent the last hour trying to bend them into shape. I can get a comfortable fit, but not a good clamp. It’s not like my head’s tiny either.
Feels like the more I try to get them to clamp the looser the fit is.
Yea I don’t think I’ve ever been more frustrated with an adjustment system in my fucking life.
Ok. So I finally got it to work. Took about an hour and a half of constant bending and adjustment to get the band a semblance of flat/straight/clamp/even. That was obnoxious. I would HIGHLY prefer adjust any of my other headphones to the constant bending of this. ahhhhh
haha yeah it can take a little fiddling to get it just right. The upside is once you have it the way you want it, it holds the shape remarkably well. I haven’t had to re-bend mine since I received them back in march
Yea, exactly. I still don’t have it perfect. I’d really love to totally flatten it and then bend it from new.
Honestly debating asking ZMF if I can buy a total replacement head strap / mount. It’s still not right and it’s driving me crazy. Whoever had these before really fucked the strap up (the angles were ridiculous). Haven’t completely figured out how to unfuckify it yet. You really shouldn’t have to spend 1.5 hours playing with a headband to get it right lol
yeah it looks like you have the old chassis anyways, so you could definitely just order one of the newer style magnesium chassis with headband. be pretty sweet and would cut down the weight a bit too
yea. I gotta figure out what the price is first though. Wicked tempting.
i think the magnesium chassis is $250. I’m not sure if it includes the headband or strap. I would just email Zach and ask about it, he is pretty responsive and helpful even to secondhand owners :+1:
You could also go with a newer aluminum chassis as well, if you don’t want to get the premium magnesium chassis.
Real questions, has anyone ever thought that the Eikon sounded ā€˜thin’? I decided to do a bunch of switching today between my sources and cans and I’ve run into a mental block. My PM-50s are suppppper warm / muted in comparison to the Eikons and the Sundaras. The Eikons just feel like super Sundaras that happen to be closed . However, both the Eikons and the Sundaras are sounding thin to my ears, especially in the upper mids / treble. Has anyone experienced this before? Like the music still sounds good, but I’m really taking issue with the timbre of all three of the cans right now for some unknown reason.
Seems to happen on some recordings much, much, much more than others.
All on the same amp?
I’d never describe an Eikon as thin, and I’d consider timber to be one of it’s strengths.
What amp/source?
Monolith Liquid Platinum with stock tubes plus and Enog2 as the dac. Running balanced.
Also Archel + enog.
I get the same feeling with the Sundara.
Idk if this is a psychological thing or what, cause it only really started happening after I’d switched around a bunch.
Like the snares in Ramble On sound really weak. Idk if I’m just noticing recording differences or something.
But Real Situation sounds fine.
Ain’t Got You has an accurate timbre and super detailed, but I can’t shake the thin feeling sound. Dynamic range is still great, all the detail is there, I’m still tapping my feet, but it just feels flat.
I think I’m just going insane.
yeah… we all are!! (the insane part)
