Hard to say. Depends on how strict your customs office is, what the local VAT is (usually 20-25%), and luck. You might be able to get away with parcels under 99USD but I know some European countries are super strict. If youāre concerned with tax you should go for EMU Walnut as they always mark parcels at ridiculously low value.
The triple drivers are actually on Drop for $160 rn. Iām starting to get concerned about the pricing of the triple drivers where i live. I feel like itās too good to be true for them to only cost $124, but they are being sold on the official 1more online store, so I hope I wonāt get ripped off.
Iām from Singapore and I always get my gears and headphones from US. If youāre here too, Iāll be able to share more info with you!
Iām from Indonesia, which is close to Singapore. Any info would be appreciated, thanks!
They can be found for 124⬠too, so does not strike me as too far off.
I just bought a pair for ~121 Euro here in Denmark. I got the silver version, even though previous posts seem to indicate that the silver version is not sold in the EU.
At first they sounded a bitā¦thin/hollow/anemic, but after my ears adjusted to them, I quite like them. They do some genres better than others, but thatās how it is with all headphones.
In pictures they donāt quite look as nice as they actually are. They seem well built, with some nice heft without being heavy as such.
Do you have any headphones you can compare them to?
greetings from a fellow dane
Hello, fellow dane
No, I donāt really have much to compare them to. They are quite unique in their sound, but in a good way. I believe that the last pair of headphones that to me had a somewhat similar way of delivering sound, was the DT990ās. They somehow separate the lows, mids and highs, so you really get a sensation that they are separate parts of the musicā¦Iām sorry I canāt describe it better.
Can you run these headphones balanced? Is it sufficient to just get a balanced cable? I know some headphones canāt be driven balanced unless theyāre modded
As thereās separate connections (left/right) thatās not a problem.
Finding the right cable is⦠
The sockets on the cups are 2.5mm.
This seems to suggest You can just search for Sennheiser HD700 cables:
The 2.5mm sockets are very deeply recessed and the connectors have to be very thin.
I bought this cable (4.4mm to dual 2.5mm) and it didnāt fit (plugs are to wide):
These might work (You could ask the seller to measure the plugs diameter and length where it becomes thicker).
Xinhs can do it. Or you can go with an mmcx to 2.5mm adapter.
I donāt think people have looked at it. I used an aftermarket cable meant for hifimans via 2.5mm and I feel the tweeter did not work with other cables. So that lead me to believe that there are 2 separate hots for each cup/driver on each side etc. I could be be wrong, but I was convinced of it when I had a pair. Swap cable and boom no tweeter so it sounded like crap.
Iāve actually heard about that before, so Youāre probably right.
Sounds like both the tip and the ring should be hot (+) and the sleeve should be ground (-).
I believe I read about the Sol Republic Master Tracks headphones being compatible.
Iāll check my original cable later with a multimeter⦠
As far as I can tell the tip is hot and the sleeve is ground on the 2.5mm plugs.
No connection on the rings.
I would think that a TS cable would work then. Like this one:
https://a.aliexpress.com/_m0N2fJG
If it fits that is⦠![]()
Was Your cable with TS or TRS connectors?
Yea my og cables were trs but the other one I tried were mono 2.5mm if Iām not mistaken, I didnāt have a multi when I experimented back in the day. Glad you checked, Iām glad to be wrong in this case.
Just tried an unbalanced cable made for these headphones and they also work:
https://a.aliexpress.com/_mNwFAVy
They have TRS connectors and both the tip and ring are hot on them.
Hi,
It is probably the screws holding the Maserati wheels. lol. Theyāre use to press and hold the glass down.
My modded Tridents.Definitely sounds better then the original version!I love the new pads on them:the original takstar pro82 pads!!Hard to decide which sounds better on tube:These or ndh 20 ![]()
Hi, I know this is really out of know where and late but, what cushion, sleeve are you using for the headband?
