šŸ”¶ 7HZ Timeless Planar
:crossed_fingers: I guess you’ve tried another cable or even the lefthand mmcx on it?
Yes i have 3 mmcx cables always the same problem IMG_20211128_112411
I think the problem is in this thing its a bit deeper then the other side so the shaft can’t touch it well
Well in doubt Digi-Key has everything
I think i will try this
Hope it will work :crossed_fingers:
good luck. make sure it fits the timeless’ case if you haven’t already
I’m buying it based on this pic :laughing: @blanche
Haha you got this!
Definitely above my skill level, I guess :smiley:
Good luck!
Thanks to all of you guys :raised_hands: i will try my best to save my child
Mine isn’t quite that bad, left side connects easier and seems secure but also spins freely while right spins with some resistance and is also more difficult to plug in or unplug. So I guess either the male pole at the center is bent a little or the female side hole is not a perfect circle. But it works so I’m fine with it for now.
I did contact HifiGo and sent a video saying I want a replacement cable but 1. I don’t know if it would fix it because while it’s the cable that’s at fault, what are the chances I get another and it’s the same issue and 2. I don’t want to pay for express shipping to fix what I didn’t break.
I’d try a different cable by the housing on my fh3 cable is too wide due to the faceplate on Timeless.
It is 100% the cable tho. Because if I reverse the channels the left side gets resistance and right spins :slight_smile:
So I’ll live :slight_smile:
Definitely. It’s just so prominent once I heard something that doesn’t have it. But I do think it’s a combination of BA presentation, coherency and driver capability compared to these single drivers.
In my case its female side hole is not a perfect circle and a bit deep . If it works u don’t need to bother ur self . Mine some time stop working when i move the cable to certain degrees
Ok, so because Timeless has so much bass i find thia sufficient.
I present to you, a 3 filter PEQ tuned to harman without the bass shelf. Curious what you guys think.
Hi experts ; ]
Any of you have or had the Timeless and IKKO OH10 and can shortly compare them please?
l’m looking at buying one of them and both seem to have a tuning l will like.
Thanks
This is just a short impressions video: Ikko OH10 Obsidian | Best $200 classical and jazz I've heard - YouTube. Dan will post a full review in the future. Recommend you subscribe so you’ll be notified!
imo if you can get the OH10’s under $150 (I got mine for $130) get them otherwise if you don’t feel like waiting for sales the timeless (timeless is on sale for cyber monday btw) I’ll do a quick a/b in a bit
Thanks so much!
I see the oh10 for 132. Timeless l see for 189.
I need to make a choice and hopefully the right one ; )
Intuition is telling me that an IEM with BA will never satisfy me… but lm open to be corrected.
Topping A90 splitting SE to both with Tin blue foams on both, threw my playlist on shuffle and listened to a few songs
OH10 more impact, Timeless bit more clarity and separation
timeless has less impact but a bit wider soundstage
timeless has better clarity, OH10 sounds more natural
timeless somehow has the same impact but comes across cleaner
other things to note
accessories wise timeless is better (more tips + nicer cable) Edit: also a hunk of aluminum case (not exactly pocketable though)
timeless needs a bit more power (might not get the full experience off a phone)
OH10 is a bit heavier but the timeless is larger
Thank you for helping !!!
It sounds like a real toss up as they say…
For the phone l have the Xduoo link so l assume l can power the Timeless…
Well… l have to decide…
Which one do YOU enjoy more?
Thank you
