do you experience hissing with the hip dac high gain mode ?
I generally listen to the Timeless via my FiiO M9 DAP on 2.5mm Balanced with High Gain ( and Balanced Boost) with no observable hiss. Equally, I find no hiss when attached to the Hip DAC when using either the M9 as a source or when using my Samsung A50 & USB Audio Player Pro. Just a greater all-around sound. Planars LOVE power. As an analogy, you can make a Ferrari do 100mph in 3rd gear, but it does it so much better in 5th. Some headphones and speakers just run better with a greater heft of power behind them.
yo iâd take those off your hands if still available i love collecting tips >: )
The FiiO M9âs 220mW power enough for the Timeless ?
OPâs not replied yet but @ttorbic has first refusal Iâm afraid.
I have a random collection of spare tips. Iâll DM you
I would say so, yes, easily. It may be harder to drive than many IEMs but itâs still an IEM. It has an impedance of 14.8 ohms and sensitivity of 104dB/V which is 89db/mW.
The Qudelix 5K (max 4V / 240mW) quotes voltage on the volume screen, at 50mV / 0.17mW I calculate itâs at 81dB and it seems loud. Thatâs almost 1,500 times lower power than the max. I couldnât go remotely near that without blowing my ears out. So I suspect 220mW would also be fine.
Regarding the hissing, I havenât tried on a HipDAC but I doubt youâd get hissing with these. You typically get hissing with very sensitive IEMs and these arenât sensitive, they are quite hard to drive.
I mean what youâre saying is that it doesnât make much sense to buy an amp with 1200mW out, because it wonât sound any better the Timeless.
My desktop amp is 1.5W, but I use them on the Quedelix or BTR5, both of which are 240mW. Theyâd be fine on a 1.2W amp as well, but you wouldnât need that or be using anywhere near the max. They are fine on the Quedelix or BTR5 which have similar max power to the Fiio M9 you mentioned, 240 vs 220 makes no significant difference; Iâm nowhere remotely near the max power on it. I think these are the sort of IEM you sort of do need an amp for, more than most IEMs. They donât sound as good out of my laptop. But portable amps with 220mW should be more than enough.
Iâm not a techie but my TimelessâŠchain DX312 > MT-604 (MT-604 maxed out and use the DAP as a pot) both the og P1âs and Timeless suck up a lot
without getting exponentially louder just âbetterâ not like say Androâs and other low impedance BA setâs so ![]()
âif we put the shit on the shelf there wonât be any jam yetâ
Happy new year guys !
So far my experience with the Timeless has been indifferent to source. Playing between the JDS Labs Element II from my desktop, from the BTR5 and direct from my phone (Motorola X4) itâs the same. If I had to pick the Bass is a hair more controlled in the Element, but is so small of a difference that may be Placebo.
Edit: autocorrect changed some word to Portuguese, sorry.
The M9 drives it with plenty of headroom. I concur with @Ohmboy , the Timeless thrives on my Topping EX5 > MT-604 set-up, with the 604 at full throttle, and the EX5 as a control unit.
The Ifi Hip DAC drives the Timeless effortlessly, itâs a joy to listen to.
What do you mean thrives ? Gives the extra power more bass quantity, clarity ,details or something ?
All of the above. The MT-604 is a valve pre-amp, A-Class 2watt headphone amp. It brings out the best in the Timeless. Greater soundstage, separation, resolution, clarity, sweeter treble, all the things you expect tubes to give to your IEMs and headphones. Iâm not a reviewer so I shall not attempt to describe it as I wouldnât do it justice. Suffice it to say, the Timeless sounds better in every respect. I plug my Timeless into the MT-604 just for the joy of listening to it. It sounds fantastic.
I feel a BasX A-100/DT880-600 energy comingâŠ
so⊠nobody notice the release of the shuoer s12 ? the graph look identical to the timeless, at least for bass and mid region. And itâs 70 bucks less.
Weâre all waiting for reviews and hands-on impressions. Many of us here are waiting for our sets to arrive in the coming weeks!
It certainly looks similar to what you say based on MRSâs measurements, but we wonât know for certain until itâs âin the wildâ, so to speak.
Jup. Itâs even got itâs own thread.
I donât remember where it was mentioned but it was already pointed out (maybe here, maybe in the ârumors and releasesâ thread or in BGGARâs or Rikudou_Gokuâs thread)⊠![]()
Got my pair. Within first 10-15 minutes (no tip rolling, burn-in, or higher power sources) Iâm split between these two bullet points:
Imaging and separation are next level
Whatâs being separated has an odd timbre (a taste of the âplanar timbreâ Iâm assuming. It doesnât sound natural to me and Iâm not a fan. From bass upward.
I like the overall choices in the FR/tuning. Maybe itâs a planar thing. This is why Iâm at least slightly considering spending s lot on something like the dark magician, or other pricier single DD. The Serial is a great triple DD but I notice it pulling away in cases where it counts for me, like texture and details of bass guitar.
