SpiralDot all the way for me so far. I only have the original ones, though; need to order the new stuff!
Thanks for your kind reply mate!! Appericiated
Hi, do you found sound improvement with Spidot, or just better comfort?
âHellĂł my dear friendâ âPlease send for me a destroy videoâ
Yeah, for me Spiral Dot seals better than the stock tip and most importantly softens the treble the best of tips I tried so far. But EarFitLight 2âs are more snug, just because they are more firm/stiff.
The new Spiraldot is the Spiraldot++ ?
Iâd be interested in these in every respect but I just donât like the look. I already feel a bit ridiculous wearing the slightly oversized Clairvoyance. These look like youâre stuffing black coins in your ear.
Wow Spirals being wide bore are know for highlighting the treble, seems the tips you were previously using werenât sealing properly?.. that would make sense as a bad seal loses most of the bass leaving the fq response off balance and treble biased.
Yeah, newest model, AFAIK.
I feel they do quite well with treble. But the stock tip didnât have much bass, then EFL2 had bass but too much treble. Iâm sure the 3rd tip Iâve tried canât possibly be the best, though lol. Or maybeâŠ
True. Boosts mids and doesnât tame treble peaks. (I only have Spiral dot, not ++)
Gotcha same as me whatâs the difference between og and ++?
According to Riku, OG and less bass more treble. Also isnât as soft. I gotta buy them but they are expensive
Yep same for the UK
IâmâŠ
Im using Spinfits, but i use them everywhere, best seal and comfort for me, tried all the tips it came with, the hazy clear yellow stock tips would be the tip i would use other wise, but it definitly had less treble
Really tempted by this setâŠI donât need it but jamming my P1 on the DX312 just wonder how that would sound
The purple/navy tips personally bloated the bass a bit too much. Couldnât get a good seal with the black ones. Would absolutely agree that the translucent tips amongst the stock tips where the best.
They will stand out a bit, and do look big, but are surprisingly comfortable and arenât heavy. Starfields are much heavier and smaller.
Very nice! Looks good on you
Dont just talk about it, BE about it!! In all seriousness i love these, first planar set but i was surprised by the bass and details, really respond to tip rolling as well, and super effecient, my Stargate dongle powers them
Try the Cp100 XLâs from Spinfit if you can, using those currently and they brought out the treble more than those stock translucent tips, bass still great
