That might work but I wouldnât EQ anything above 13K.
That makes me remember of Crinâs DQ6 EQ preset, +19db peak on 13khz
Fitâs ok for me as is most IEMâsâŠnozzle measurements are as follows..
Bore sizeâŠ
Recessed sectionâŠ
His update is equally great. Look it up if you havenât yet.
drftr
Just a wee observation on Hey Now by London Grammar @ 1.39 the tick, tick sound that pans right to left is more pronounced on the P1âs my OCD appreciates stuff like this ![]()
Switched to Spiralâs on the hzâs for thisâŠ
To add some attack to the strings and lessen the bass which I found to be a bit âwoolyâ with the Sony tips, definitely better but still bested by the P1âs in this case imho
Man the 7Hzâs kills thisâŠ(good source)âŠ
the decay on the intro âVocalsâ are amazing, they float away like a Chinese lantern on a Summers evening absolutely stunning
it.
Guess that depends on what sets and your library ![]()
This is part of what I have been trying to figure out. The dusk feels like it is missing parts of the note. I described it as choppy. Itâs not super music dependent either.
What other BA hybrids do you have to compare to the timeless? (I have mangird teas coming in tomorrow)
Yeah the Dusk is particularly bad for coherency regarding its BAs. And, honestly, for every hybrid Iâve heard (which does NOT include the mest) itâs easy to tell when the BAs kick on and they always pale in comparison to the DD/EST in terms of timber and note weight. All-BA IEMs donât suffer from that coherency problem.
Anything other than the mest not included?
This really might be it. The sound of the DD is so different from the BA, it just feels wrong. (as opposed to purely a timbre issue).
That makes me very curious about all-ba options. I do like articulate sound. Planar speed and precision is very appealing to me. Seems like BA would bring something fast as well. DD Bass though. DD Bass.
I meant I have not heard the Mest so I cannot conclusively say it suffers from coherency problems though you can infer it probably does from the many other reviews.
Regarding all-BAs you tend to get used to the sound. Even if the note weight and slam is less-so compared with a DD you donât notice it if all you hear are BAs. And, yes, BAs are generally fast like planars. Can even be âunnaturallyâ quick as is the case with the Anole VX.
Fair enough. Teas are tomorrow. If I am still in this boat, I will probably steer clear of hybrids for the time being. Bumps the RSV way up the list though.
My replacement timeless will be here in a few days. Canât wait! I have missed that sound.
Thanks for that - Iâm miraculously healed. Thereâs only so many times you can read the same message but from different people. Cleans out my shortlist rapidly!
drftr
Could it be that BAs are TOO fast? What if we like the distortion from planars and dynamic drivers better, while BA may simply be accurately translating what is recorded in zeros and ones, making for a fast but inherently digital experience? Anyone tried listening to an analog source with BA IEMs?
drftr
I think the main problem with BA sets is for âfull rangeâ sets they generally are multi-BA. Phase and coherency issues.
I had the Aonic 5 & Aonic 3 for a time there. Both have pretty close tuning, like really close. The 5 is 3BA, the 3 is 1BA. The Aonic 3 sounded much more natural to me and the one Iâd choose, although soundstage was more limited.
I honestly donât know. The drop ether cx is stupid fast and I LOVED it. But it is entirely coherent top to bottom. Since âcoherencyâ tends to be my issue in all things, my bet is it is a mix of drivers that is the primary problem.
But, I do think if decay were really abrupt, I still wouldnât like it. Planars definitely donât feel as ânaturalâ as DD for me. But, that is not the same thing as âbadâ. Just different. And I think the ânaturalâ still comes from âwhat have I heard most of my lifeâ not necessarily âreproduces X instruments betterâ.
Fun stuff. Will have more info soon.
