I hope its a tiny pillow thst says âsorryâ on it
HAHAHAHAHAHA
Before returning my lcd-x I directly asked about the GX. They said itâs just not a fair comparison. All but refused to send me a pair. The LCD-X is a monster headphone so I doubt putting those drivers is a lightweight frame has anything but major ramifications.
As for something close to Diana I think the focal clear is a really good competitor. S tier headphone, unique driver (though not planar), and very comfortable.
jw if the pillow came in lmao
It did. Itâs a stick-on pad. Itâs livable now. Not comfortable but livable.
Any chance you could post a pic?
Dude, youâve had the patience of a saint through this. Iâd have bailed a while back. Kudos for sticking with it but my OCD couldnât handle anything even remotely near that âfixâ.
You know youâve probably in the minority on this and Iâm sure most people wouldnât even have a problem. Iâm accustomed to hearing helmets so weight isnât an issue for me. I can also say thatâs Iâve never experienced an issue with any headset Iâve put on, hot spots etc. Iâm thankful for that.
Just had to mention that youâve been a trooper through this. Hopefully youâll find something that you can live with.
I have half a mind to make some elegant solutions to the pads and headband and sell them to Abyss for $2999.
I should not read that but i need to read that
It is exactly what you imagine it would be. I may have missed it but im not even sure they list the chain used to listen.
yep very similar to their âreviewâ of the Focal Clear.
I can poke multiple holes at those measurements lol.
The king measurements dingus says his headphone distorts playing them loud as a speaker. whodathunk it.
I swear the fact that there is a literal cult of personality around his crap baffles me.
I find it âamusingâ he clearly didnât manage to get the pads to seal on the measurement rig, even notes it. So whatâs the point of the measurement.
And this
That while the pads nicely rest on the measurement rig, slight deformation of them radically changed the response especially in the 2 to 6 kHz region.
Welcome to the world of headphone measurements.
I have my issues with most of the sites content, but his speaker and headphone measurements are terrible.
It probably doesnât help that the diana specifically arenât supposed to seal for best sound, and will change their sound overall depending on how you rotate pads, so I assume that would make accurately measuring them a pita
And why on earth would you measure distortion at 114 dB SPL?
Thatâs permanent hearing damage in like 30s area, whatâs the point.
I would also expect that most drivers were never made to really handle that spl well, considering that tuning a headphone to take and preform well at that level would be extremely stupid, there are headphones that handle high volume better than others, but I really doubt most headphones would preform well at such a high level
All hail the Master of Measurements, the Lion of Linear, the Freak of Flat. Do not doubt his wise ways. 114db is loud for mere mortals, but is leaves rustling to a 60 year old half deaf man!
He has his preferences i guess and some people like that. I personally think the graphs are a guideline at best. hearing is believing and no graph replicates that adequately.
