Hello,
I was recently faced with a similar choice.
Of the planars, I have always been attracted to the Lcd 2 c and the Aeon 2.
After a lot of research and reading, most of what I heard was that the Aeon 2 was a bit boring compared to the Lcd 2c.
And I decided in favour of the lcd 2c.
Overall, I think it’s very good, and I can’t confirm its criticised weight.
I find it just right, and the comfort is also very good.
I think it’s a stunner in terms of sound.
The mids are quite strong, and the highs are not too sharp.
The only weakness it has is when you listen to hip hop it will be too thin.
It’s not so good for that.
For Jazz,Blues,R&nb,50% of the charts,Electronic and Rock music it performs best.
Although he seems to be dark, he is really fresh and lively and gets to the heart of everything.
Compared to the Aeon 2, it needs a little more juice, so the amp should definitely be suitable in terms of power.
With the Aeon I like the Fazors option, but was unsure if it could satisfy me.
What bothered me was that if I wanted to listen to a certain type of music, I might have to change the Fazors.
That gets annoying over time if that’s the case.
As for the Emu teak, which is pretty much identical to the famous Fostex Tr x00, it has by far the best bass.
Also the options to customize it with additional Emu cups like Ebony,rosewood,Sapelle ect as well as the Lawton mod are excellent.
The possibility to customize it to your personal taste is definitely there.
However, if you tend to be stuck between Aeon and Lcd2 c, it would be better to listen to both and then decide for yourself which is your favourite.
What kind of setup do you have that hasn’t been mentioned yet
