Brand Introduction:
Aful Acoustics has always targeted a strong and experienced acoustic R&D Team. They have adhered to the simple concept of “Only Real Progress in Technology can bring Tangible benefits to the Consumer”. Four Years Ago, AFUL Acoustics was founded to bring a change to the HiFi Audio industry with class-leading IEMs and Headphones at pocket-friendly prices.
After painstaking research by the team for over two years, Aful Acoustics matured the basic technology in 2020. Ever since then they have got several different technologies such as EnvisionTEC Medical-Grade 3D Printed Acoustic Tube Structure, 3D Air-Pressure Balanced Relief Technology, etc.
Brand Social Media:
Facebook: https://www.facebook.com/AFULAudio
Twitter: https://twitter.com/AFULJP
Products information:
Highlight— 1 DD+ 2 BA IEMs
1、Acoustic Bass Tube and 3D Special-Shaped Resonator
2、Precisely Designed Multi-Layered Electronic Crossover
3、The fusion of Magicone Concept and P Series Concept technologies with 3 units, promising quality sound and comprehensive output.
4、Wide Frequency Response Range
Technology and Sound Characteristics
The integration of P Series and Magic One Technical Concepts
Magicone Concept: 1 driver unit for complete sound representation and magical sound.
P Series Concept: The sound of each unit is precisely integrated to achieve a complete musical experience and Deliver a fuller sound.
Explorer: The fusion of two concepts and technologies with 3 units, promising quality sound and comprehensive output.
Why do we name it Explorer?
Due to the use of a panel themed around the cosmos, exploring the infinite possibilities of the stars, coupled with the unique tuning akin to the Performer series, and the widespread preference among most friends for the name “Explorer,” we have decided to name this IEM Explorer.
Acoustic Bass Tube and 3D Special-Shaped Resonator:-
RLC Network Frequency Division:-
Innovative Technology brings excellent frequency response curve
High Damping Air Pressure Balance System:-
Sound Description
Technological Innovation
All drivers are imperfect, traditional technology has reached the limit of the driver’s own capabilities, and it is difficult to break through to bring substantial sound improvements. AFUL’s latest Explorer creatively combines MagicOne and P series technologies and concepts, achieving a new level of sound with three drivers.
Feature 1: Wide Frequency Response Range:-
A relatively wide frequency response range will make the instrument presentation accurate and realistic. Not only does it express the main channels, but it can also perfectly express the harmonic tone. However many in-ear monitors on the market can only express the main frequency band and cannot present the overtones because their frequency response is not wide enough.
Technology to make it all possible?
The current tuning in the industry is basically changed through very simple circuits or sound paths. However, we used joint modeling of circuits and sound paths(Electronic and physical crossover), and through difficult multi-dimensional complex mathematical calculations, we have overcome many difficulties in the tuning.
Feature 2:Consistent High-End Level Performance:-
P3 has excellent low volume, it does not affect the expression of mid-frequency vocals and musical instruments. The expressiveness of vocals and musical instruments can be achieved at a high level at the same time. These qualities are undoubtedly the qualities of a high-end set.
Feature 3: Easy Driveability:-
P3 does not come from blindly stacking multiple units, it relies on the precise acoustic structure and electronic crossover to bring acoustic correction and deep matching between different drivers. It has a high degree of easy driveability. If you have a good quality Hi-Res audio player, you will realize its better potential, but if you are using a normal decoder or a Bluetooth module or even a smartphone, you can still hear relatively good high-quality sound.
Sound Signature / Sound Characteristics
Lower End: Elastic, Deep Diving:-
Features high-quality dynamic driver unit
With the ultra-long low-frequency acoustic tube, the ultra-low frequency characteristics show better extensions
High damping pressure relief pipe, while removing the ear canal pressure, it makes the low-frequency better textured and responsive.
Vocals:-
Real and Warm, while ensuring a sense of atmosphere and air. It shows well-textured vocals.
High-Frequency:-
Treble area, smoothly extended, ensuring the authenticity of instruments and their overtones.
Easy driveability:-
Very easy to drive, It is recommended that you try it with Bluetooth ear hooks or Bluetooth Decoder. The response will be much better than most IEMs on Bluetooth.
Recommended matching and suitable music:-
It has good adaptability to various front-ends. Suitable for Pop, and also complements Classical symphonies, etc.
Explorer is an entry-level-priced set of IEMs with high-quality sound quality.
Specification
Model: AFUL Explorer
Impedance: 26Ω ±10%
Sensitivity: 108dB/mW
Frequency Response: 10Hz - 30kHz
Cable Length: 1.2m
Driver Configuration: 1 Dynamic Driver + 2 Balanced Armatures
Cable Connector: 2-Pin (0.78mm)
@Ohmboy could we move this to a product page, please?
