šŸ”· AKG K361
I would definetly say so, it’s hard to pin point everything but brighter sounds (treble) are im pretty sure literally louder making the song sound bigger(louder) and fuller. i don’t wanna comment on other things since i can’t really explain them properly lol. don’t wanna spout snake oil. maybe someone can comment about things to look out for in FLACs over mp3s. that would be cool
The main differences come from spatial information regarding lossy vs lossless imo (also flacs are just more detailed and resolving too with better naturalness). A lossless file just has more apparent information in it that allows for better recreation of space imo
interesting, niceeeeee. thnx for the input
Has anyone tested AKG K-361-BT with Huawei P20 Pro or Huawei Phones? There was 1 guy complaining the bluetooth connection had issues with Huawei brand, because the volume adjust didnt work at all there
I have one pair of K361-BT, but only a Motorola X4. I will say the control is a bit off though. There is kinda of a ā€œlimited touch regionā€, and a I still sometimes miss it. But overall everything is working, it just take some time to get used to it.
Just posted my thought here on this headphone:
These are great value for money headphones which offer an excellent implementation of the Harman curve for those that like the Harman curve at a bargain price. The main issue is build quality,the low rent feel is OK at this price but even low cost products should be usable without falling apart. I know one guy whose headband snapped after about 8 months and another whose swivel mechanism broke apart after about four months. And fit and finish seems variable. And although these are great value for serious headphones they’re not being given away. If AKG could nail the build quality I’d recommend these as a great product to anyone who likes the tuning, but as it is I’m hesitant…
Hello everyone, first post here!
I’m in turmoil in choosing between the AKG K361 vs the CM MH751. Would like to hear opinions on it between the two! Thanks for anyone replying!
Hey everyone! I received a pair of K361’s second hand and it only came with the looooong cable. Has anyone had luck finding a replacement or any other shorter cable that uses the same locking connector?
I believe the cable is the same as the Sennheiser HD500 family, but I’m not 100% sure. If it is, something like this should fit.
https://www.amazon.com/NewFantasia-Replacement-Upgrade-Sennheiser-Headphones/dp/B00KAKBHKM/
Hello, I’m considering buying the K361BTs. I can’t seem to find any consistent opinion on how they compare to the non-Bluetooth version. Are they worth it? Are there any other Bluetooth headphones in this price range($100-$200) that are a better choice? I’m not necessarily looking for ANC, just BT.
