Is this headphone worth it for 350$? is it the best AKG?
The âbestâ is subjective
yeah but is it the best?
yeah but the best for you might not be the best for another, its an impossible question to answer.
yeah but⊠is it the best?
why try and troll?
We can go round and round about all the features and go into details till weâre out of our little white minds. but the question will still remain. Is it the best?
Well im looking on their web site and i see a 800 series. priced at 1500$ i woul assume those are better than these. maybe even⊠the best?
From what i heared of its compared to the stax in pinpoint accuracy
I personally think for the price that the 1990 pro would be something to consider instead of the stax
So which is better in soundstage and imeging to pinpoint the sound btween the akg712 and 1990 and still i want to know whats the amp and to use with them ??
The 1990 does the better job at that imo. Do you have an an amp already, of are you looking to buy an amp dac setup?
I have fiio olympus 2 e10
Hmmm, you may want to upgrade, how much are you looking to spend?
I dont know still i will see the all options first
I was thinking something like a jds labs atom and a topping d10 stack would offer large bang for buck and upgradability in the future
Thank u i will see the prices and specs first just can u tell wich one is best bang for the buck and wich one is best all preformance?
Well best performance is quite expensive, so letâs go for performance under 1k. The Rupert neve rnhp and smsl su8 would be my pick for your use case imo.
Bang for the buck would be like the stack I mentioned above or something like the fiio k5 pro.
Something in between the bang for the buck and top tier performance might be the enog 2 pro and archel 2.5 pro stack, which is pretty sweet imo
What about ifi zen is it good for dt1990 pro
Personally no not for the 1990 since you canât take advantage of balanced, the zen dac isnât the best using single ended, I think the fiio k5 pro would be a better choice in this situation if you wanted a more budget all in one
