As the topic states, I’ve been sitting on a SMSL SP200 since about the time it came out. I’ve been pairing it with the Harmony Design DA9 and later the SMSL Su-8. I quite enjoy the sound it produces, but over time I’ve come to be annoyed by its shortcomings.
I love the power it pushes, I like the ease of use with the flip switches and I’m okay with the overall design, even if the form factor is a bit lopsided. I love how it makes my LCD-2 CB, HD700 and Starfields sound.
I dislike the volume knob, a lot. The way it doesn’t give any volume increase whatsoever after 2 o’clock drives me mad on some headphones. The absurdly steep gain for some headphones. This makes swapping between HD700, LCD-2 and Starfield an annoyance as I either have to change gain, DAC output etc. Which also screws with my speaker volume as they are run via the Su-8.
So I’m sort of at a loss at what to do and where to go from here. I kind of miss my old Harmony Design EAR90 in how good that volume knob was (I think it was the top of the line ELMA controller of the time of purchase in 2006/7). I miss that tactile feel and the smooth increments in volume. But overall that amp can’t drive my IEM’s without driving me insane with the hiss.
So what do I want?
- Improvement over SP200
- Balanced XLR / 4.4 (latter not requirement, but preferred)
- Better gain steps?
- Be able to drive IEM’s / Low noise (not an absolute must, but nice bonus)
- Good volume knob / response
What is it being paired with?
- SMSL Su-8 DAC
- Klipsch R-41PM
- Sennheiser HD700
- Audeze LCD-2 Closed Back
- Fostex T60rp
- Moondrop Starfield
Use case is everything from music listening and gaming to amateur recording / streaming / video production.
On a side-note, I’m using a Yamaha AG03 Interface that I originally bought to patch into my amp or via the DAC in some Frankenstein setup, but ended up getting horrible screeching noise on it. Although I’m not sure what the cause is, but I suspsect USB noise or overlapping cables causing it. Either way that’s probably another topic for another time.
Budget is not set, but I would prefer to keep it sane, no $2000+ pieces. This is more going to be a project over the coming year, so I don’t particularly mind saving up for something. But if I can stay at a relatively sane level then I’m very happy.
EDIT: On the note of IEM’s, it would be a nice bonus since I have quite a few and like using them from time to time at the desktop, but they are mainly used on the go for me. Main use for the desktop rig is primarily full sized headphones.
and of course the price kept falling. I think now it is $399.00. THAT is a killer deal!
