I think the pain may come from a motorcycle accident I had in my 20s. Likely irritates an issue with compressed discs that already exists.
That said the 2 series are a hundred or so grams lighter than the X from Audezes reporting.
What about the carbon fiber head band for the LCD headphones? Also⦠The headphones to get I think for you would be the Abyss Diana V2.
Iām terrified youāre right about the Diana
I also weighed the steel headband and it came in at 54g vs the 60g reported from Audeze on the CF band. Iāve heard the CF also has a higher clamp force. If there were a significant weight advantage to the CF band I would probably go for it. Itās wild that it could weigh more. In general I think Audeze should invest in some quality scales
Do Dianaās ever go on sale or do they sell open box? I canāt find anything like this.
Just jump on deal when you see them. But if you want high resolve and bassy, worth every penny⦠So Iām told. There are some Diana V2 owners on here but I can say the GS X mini + Diana Phi that I have is a match that cannot be over looked. The V2ās will probably sound even better if you want that and resolve better than the LCD X.
Reread what I wroteā¦sorry if that came off dickish. Didnāt mean it to be. I get it with old injuries and sometimes I lose sight of how individualized this hobby is.
Reported Masses
LCD- 2 Closed Backs 1.338 kg ~ 2.9lbs
LCD -X 0.612 kg ~ 1.34 lbs
And then based on reddit:
Thatās my internal debate. Phi seem to be a larger upgrade. And thereās part of me that can say if itās $3k it might as well be $4k.
Hopefully Iām able to find a deal sometime in the future. Though Iām generally more comfortable buying new because of warranty issues Iāve run into.
No worries, I have said probably the same thing in other context
Donāt equate money = sound quality. Honestly the only reason why I got the Diana Phi is that a dealer in Las Vegas was closing their shop. I literally got got the Phi at the V2 price⦠but with a cable that is so far still useless to me and without the DMS ear pads. Honestly, the V2ās still have an appeal that make me consider buying both, but itās because I know what I want in my sound signature with my setup. I have a feeling the V2ās may treat you better than the Diana Phiās, and the only reason I bring up the V2ās is that they are light so youāre not worried about weight as much.
Just trying to help and give perspective. Also make sure youāre not missing out on something you enjoy with LCD X seeing how you see the need to part ways with the headphone.
I received a great used LCD-X a couple of weeks ago, and Iāve got to say, the LCD-X is really fantastic****
*weight
*driver variance
*pad heat
*EQ may be needed for some people on some units
Those asterisks may be non-issues or complete dealbreakers, but if you can deal with those, what youāre left with is a phenominally detailed, fun, and impactful set of cans. Between this and my Focal Elex, Iām totally set with headphones until Iām at a place in my life where I have way more money than sense.
You just canāt beat the speed, impact, and enormity of the LCD-X. I mean, talking about soundstage is just funny to me with these because it sounds like Iām strapping two giant concert guitar amp stacks to my face. These are just absurdly good at rock and metal.
When I got them and first put them on, they made everything sound compressed, like all my FLACs were suddenly 128kbps mp3s like they were 20 years ago. I bought them expecting I would likely have to EQ them, and I knew the risks going in! Thankfully, I figured out a few EQ profiles that Iāll probably write up in a separate post sometime so that people can reference them and try 'em out if they feel like it.
Iām also happy I finally own a good set of planars. I tried and quickly returned a couple of cheap planars about a year ago. The HE-400i had a strange timbre to it and had poor build quality, and the M1060c was just painful on every level. After expereincing two sets that felt like they would fall apart at any moment, the LCD-X couldnāt be a bigger contrast when it comes to build quality.
I figured Iād share some of my work with EQs for the Audeze LCD-X. I reverse-engineered a couple of corrective parametric EQs from Sonarworks and from Crinacleās headphone database, which had five different samples that I averaged from. So, if you like what Soundworks software does to your LCD-X, I have it for you here in PEQ form!
Some background: I was prepared to EQ these when I bought them used, and was partly encouraged by a recent video by the Headphones show specifically about EQing the LCD-X. I used his EQ, and the result was hilariously awful on my set!
He didnāt do anything wrong, but his was a 2020 while mine is 2018/19, plus unit variance⦠yeah this wouldnāt be easy. So I did some research to figure out some way through the unit variance issue, and I found Sonarworks first. I used their trial and tried out their EQ, and it sounded much better, but it was proprieitary to their software and setup. Fortunately, they showed what their corrections were doing, so I built a parametric EQ that matched their corrections. I also found that crinacleās graphing tool had five different samples showing similar things, so I did the same process there.
Iāll put the EQs in the next post. Personally, I prefer the Crinacle EQ, as the Sonarworks one can be a little harsh on some songs on my set.
Both of these EQs require a 10-band PEQ.
Audeze LCD-X Sonarworks EQ
Preamp -7 dB
All filters in this one are peaking filters
Audeze LCD-X Crinacle graph EQ (5-sample average)
Preamp -9.2 dB
First entry is a low-shelf, the rest are peaking filters
If you have more than 10 bands, this will be a bit more accurate. Keep 1-5 and start from here:
Protip: Keep your settings in GitHub or GitLab.
Great way to share and save your EQ settings.
My EQ for LCD-X for Equalizer APO:
GraphicEQ: 20 -10.53; 24.9 -10.46; 32.3 -10.53; 40.4 -10.53; 50 -10.46; 64.8 -10.53; 80.2 -11.01; 99.8 -11.69; 126.7 -12.3; 156.6 -13.45; 199.4 -14.07; 266.7 -13.79; 347.8 -13.37; 434.7 -12.16; 500.1 -13.66; 579.3 -12.5; 770.8 -14.88; 1004.1 -13.18; 1415.3 -10.06; 1794 -6.63; 2169.9 -2.58; 2491.9 -0.95; 2797.2 0; 3286.3 -0.27; 3929.1 -1.83; 4994.5 -3.74; 6013.4 -3.53; 8028.2 -3.67; 10099 -6.18; 13271 -6.8; 20038 -9
Filter: ON HS Fc 610.98 Hz Gain -3 dB
Preamp: 3 dB
always one thing that make me hesitate to choose lcd-x is deviation? variation? of productā¦
from 2016(just time when I know about lcd-x) to 2020,
is there a certain improvement or consistancy on sound signature?
someone says it is great as stock, but other says need EQā¦
also on measurement side,
innerfidelity / diyAudioheaven / suberbestaudiofriends / reference audio analyzer / oratory1990(lcd x was removed) / crinacle(in ear fidelity) / headphone show / etcā¦
I can not sure which version they measured and using EQ or notā¦
I knew most of them was measured just as stock,
but some of measurements shows quite neutral against otherās typical audeze-like signatureā¦
which one is right? so confusing still⦠by any aspect, review and measurement either side.
just difference by how to explain of sound? or differences are really there?
I like my LCD X so much that the only way to find a better sound over the Bifrost 2 -> RNHP -> LCD X chain took thousands of dollars more⦠and still use my LCD X because it sounds so good and does things.
Great detail but a bit on the narrow side with sound stage. Some people really complain about the treble being harsh but not everyone. The people who swear by EQ will claim it needs EQ. Will it benefit it? Yes. Necessary? No.
My only advice is the 2020 versions seem to have less variances in quality. People complain of weight but I donāt see it, I would suggest against it if you had a neck injury but if youāve worn motorcycle helmets then itās lighter than that.
Is that thousands of dollars the gsx-mini?
Used, it can be found ~$1500
GS X mini + Abyss Diana Phiās. I can say everything else I have doesnāt have the same level of details to the LCD X on that chain that I own.
I have the LCD-X with a Modi 3 + Heresy stack. Would it be worth upgrading amp and/or dac?
