Iām sure compared to the margin on their cables headphones probably brought in a lot less comparatively
Hey @M0N Do the OG NightHawk come stock with the hybrid pad? From what little research looking for suede pads it seems I have the hybrid pads. I donāt have the Carbonās leather or Suede pads. I can find the Leather for sale but no mention of Suede pads anywhere.
Yeah I saw that too
I think so but I canāt recall
Looks like I will have to try some aftermarket pads⦠There was one post i saw some guy got good results from Audeze vegan suede pads. Might try the ZMF Universe pads in suede. Then maybe brainwavz suede. Idk.
Btw if anyone has a spare pair of the MicroSuede pads iāll buy haha.
Update: Ordered some ZMF Universe pads. No clue how Iāll get them to stay on but I reckon Iāll find a way. Also AudioQuest got back to me and of course the MicroSuede are discontinued and sold out. Though they do have the protein leather in stock for $50 USD.
Suede brainwavz pads work pretty well. They sound pretty close to the suede nighthawk pads as far as I can tell.
These are the ones Iām gonna buy along with the ZMF:
Or are these too long length wise for the NightHawks? Should I go for a more Round pad?
The round pads might look a bit weird. If youāre gonna go zmf the oval suedes could would but those are THICC
. Especially compared to the stock pads. Dunno how those would sound. Oval brainwavz suedes fit the best around the pad rings.
Nearly a week using the XD05 Plus with the Nighthawks and they keep sounding better and better. Iām wondering now if I can make these my headphones for calls too. Are the modmics still worth it these days? Are there better alternatives?
The inline mic that comes on the stock cable is okay actually. You just need to figure out how to get it to work.
Itās kind of impossible to do a modmic for double ended cables as far as I know.
Yeah, the inline works for my laptop but my PC doesnāt have a TRRS input for audio + mic. I was thinking more of the Antlion Uni or that audio technica detach mic (and i like the aesthetic).
Iām also not sure if the inline mic still works when plugged into the XD05.
I donāt think heās talking about the vmoda boom pro.
Modmic will work if you use a Y connector. The only thing is that the headphone cable should be a non mic one.
Ah. Yeah the microphones wouldnāt work if the unit is plugged into the XD-05.
Have you thought about a separate mic?
Headphones go to the XD-05, from the XD-05 goes to the Y cable. Modmic goes direct to the Y cable. Y cable is plugged to the motherboard/controller 3.5mm connector
Well there ya go. Looks fairly straightforward.
Iām all about standalone mics myself. Used to use the blue yeti but the port and cord were shit and on the bottom so bound to bend and break. Just got a quadcast from hyper x and itās legit.
Once you go desktop mic you donāt go back man. Sounds way better, no worry about breathing into mic, no extra cords dangling from your headphones.
Oh I just noticed for Xbox. Never mind then
Iām a long way from having to buy it so Iāll give standalone some thought, thanks.
Definitely. I mean theyāre overkill for gaming but so nice once you get it setup just right.
