Glad you got it to work how you like ![]()
No, I have Susvara and Modhouse t50/T60 Arya and actually lots. I do not have the DROP version though (assuming that is what the XX stands for)
Yes, it is. Cheaper but same headphone as hd650.
I will receive argon t50 mk3 today for a spin. Excited.
Susvara. No further questions to be askedâŚ
And you are still IEM guy (if I understand correctly following your content) - that speaks volumes
I had my eye on two of those, guess Iâm grabbing the third. Thanks for talking classical ![]()
Oh, man, Vivaldi is back in my life to stay. ![]()
How does Moondropâs clamping force compares to other headphones? Is it less clampy than something like Sennheiser HD600/650/6xx?
If you want something from Vivaldi that puts different instrument than violin in a spotlight, give âConcerto for lute in D Major RV 93â and âRecorder concerto in C minor RV 441â a try.
Moondrop is the least clampy of the 3. Thanks for the rec
Just got the inspiration for the afternoon⌠minus the fan ![]()
I really love the vocals on Tin P1 Plus. Itâs correct, sweet and not too forward. Vocals, acoustic, even rock sounds just like a good set of speakers on them.
You mean after EQ, right?
Anyone listen to the Unique Melody Macbeth II ,there is a local set for I was interested itâs a all BA set from UM?
Worth $200
Could you explain a bit more why you donât use the pink noise to set the volume? You said that in the beginning, but I would say pink noise is much more correct than setting it based on one single frequency for the exact reason you said why you DONâT use it
It just averages the variations around one frequency for different set making the perceived level for music (covering wide range of spectrum) played on different sets much closer to each other
You knew you would ask. No EQ necessary
Looks like Hiby are about to drop a R2R Dap on us in September.
The hiby Rs2.
If you get a review sample, would love to hear your thoughts with a comparison or two.
I have heard it. The names in Japan are sometimes different. Think itâs the Maven or Maverick over here.
I wonât go by memory but $200 seems a good price if anyone else can help you with SQ opinion
