Ignore anyone who says the Jot 2 doesn’t bring out the best of Sus. It is driving sus to 77dB in high gain with dial on 9am and it goes to 5pm so you have the bulk of the available power as headroom. It is not analytical and it is not over kill
Hello Chris, @hawaiibadboy ,I need a bit of guidance if possible. I’m really looking into buying myself a pair of FatFreq IEM’s but I’m really torn between the Maestro Mini and Scarlet Mini (I can’t really afford the more expensive ones). My library consists in mainly electronic music of all kinds really and some hip-hop from time to time. I do like bass (that’s why I was looking into the FatFreq Maestro lineup) but I’m just thinking Scarlet would be a bit of an overkill as I’m not sure how that amount of bass would affect all the other elements in the upper region given the kind of music I’m listening to. All the rest of my IEM’s are kinda following your target, I even bought the Thieaudio Hype 2 after watching your video and I’m enjoying them. I did watch your videos for both Scarlet Mini and Maestro Mini but given the time passed between the 2 releases what would be your opinion that would go better for me.
Welcome to HFG
I’d rec the Scarlet mini
The Maestro mini has a BA that can get grating as hell after a while and the scarlet is doing a treb similar to the TOTL sets with fewer drivers not at their level but it is a much nicer presentation than MM. BA’s are hit and miss for my ears and the Scarlet is a hit.
The bass only shows itself when in the mix so it plays other genre fairly well.
Example: Never going Back Again guitar (Acoustic) …not your mentioned genre but the Maestro handles that string plucking poorly while Scarlet does it well.
I’d rec Scarlet over Maestro mini
Thanks a lot for your reply, I really appreciate it!
My bassiest IEM so far was probably the FIIO x Crin FHE and with that one even though I liked the bass I found that for me the upper region had a weird tonality, not sure why, so I gave them to my partner because he prefers them. That was the reason why I thought I was going to ask you which one you think would be better and I’m glad I did, now I have a reference to go by. Once again thank you very much and looking forward to more videos from you and more of the wisdom that you share with us.
Well your reviews and opinion guided me into getting a lot of good IEM’s and never failed me so far so the trust is earned and well deserved. Happy holidays to you too and best wishes to you and your family!
The budget TWS space is heating up, curious how Mino compares to Moondrop Space Travel - I got the latter recently and it’s crazy value for $25 or less, the sound beats a lot of budget wired sets(particularly with the bass boost EQ in app) and you get the convenience of TWS.
Just checked. Seems to work like Neutron does, I got 2Vrms with my Moondrop Dawn 3.5mm both in Neutron and Poweramp.
This power value im getting is the rating you see on ASR/L7 like this:
Within 30 sec of listening to Wind I was like
“Yep, this is it chief”.
I’m hearing the 5Khz peak a little bit, as well as 2.5kHz elevation. Though it must be said I am used to a perfectly flat treble and a somewhat relaxed pinna.
Did the 5k peak calm down with playtime or only 2.5k calmed down?
If not, then I might have to apply Tanya filter to achieve that last bit of refinement.
